Thread: Well I done did it guys.(Meth Injection)
Results 1 to 20 of 35
ChrisJ Well I done did it guys.(Meth... 04-11-2009, 06:48 PM
QwikGT Re: Well I done did it... 04-11-2009, 06:50 PM
05SS45 Re: Well I done did it... 04-11-2009, 09:57 PM
Bio248 Re: Well I done did it... 04-12-2009, 10:19 AM
ChrisJ Re: Well I done did it... 04-12-2009, 12:10 PM
Iron Indian Re: Well I done did it... 04-12-2009, 03:16 PM
ChrisJ Re: Well I done did it... 04-12-2009, 03:58 PM
Iron Indian Re: Well I done did it... 04-12-2009, 11:03 PM
Iron Indian Re: Well I done did it... 04-12-2009, 03:14 PM
Reptile Re: Well I done did it... 04-12-2009, 11:12 PM
Iron Indian Re: Well I done did it... 04-12-2009, 11:27 PM
ChrisJ Re: Well I done did it... 04-13-2009, 11:07 AM
Bio248 Re: Well I done did it... 04-13-2009, 01:41 PM
Guest Re: Well I done did it... 04-13-2009, 03:20 PM
Sabrewings Re: Well I done did it... 04-13-2009, 06:34 PM
Iron Indian Re: Well I done did it... 04-13-2009, 08:44 PM
badbrad Re: Well I done did it... 04-17-2009, 10:27 PM
Bio248 Re: Well I done did it... 04-13-2009, 06:39 PM
99prixgt Re: Well I done did it... 04-13-2009, 07:10 PM
Reptile Re: Well I done did it... 04-14-2009, 11:59 AM
ChrisJ Re: Well I done did it... 04-14-2009, 05:26 PM
Iron Indian Re: Well I done did it... 04-14-2009, 11:03 PM
Bio248 Re: Well I done did it... 04-14-2009, 05:37 PM
Bio248 Re: Well I done did it... 04-15-2009, 12:51 AM
ChrisJ Re: Well I done did it... 04-15-2009, 01:03 AM
Reptile Re: Well I done did it... 04-15-2009, 06:53 AM
ChrisJ Re: Well I done did it... 04-15-2009, 01:26 PM
Bio248 Re: Well I done did it... 04-15-2009, 01:30 AM
Bio248 Re: Well I done did it... 04-15-2009, 01:41 PM
Guest Re: Well I done did it... 04-17-2009, 03:33 PM
Bio248 Re: Well I done did it... 04-17-2009, 03:42 PM
02grandprix Re: Well I done did it... 04-18-2009, 11:09 PM
Bio248 Re: Well I done did it... 04-19-2009, 10:58 AM
  1. #1 Well I done did it guys.(Meth Injection)
    Apr 2009
    Springfield,Va
    Got the Devils Own 3800 kit ordered up. Few questions about it. I have been looking at Iron's install thread and he is running it though the TB spacer. Would I be better off spraying it after the blower? Getting another LIM and drilling and tapping a hole on the front and rear so I get even spray? Alot of work yes but I think it would be worth it.
    I have read spraying it pre-blower seals up the rotors better and you get 1-2lbs of boost out of it. Also have heard it can strip the coating off the rotors? Any truth to that?
    Another thing what mix would be best to run? Windsheild washer fluid? Or get some Meth from a local dealer or order some up from Devils own?
    Thanks Guys.
  2. #2 Re: Well I done did it guys.(Meth Injection)
    May 2008
    staten island,NY
    it will not strip the coating off, we've put countless kits on cars and they are fine. i would run 100% meth, i do it in my car
  3. #3 Re: Well I done did it guys.(Meth Injection)
    GT Level Member 05SS45's Avatar
    Jan 2009
    westport maSS
    Quote Originally Posted by ChrisJ View Post
    Thanks Guys.
    if you dont mind me asking how much the kit ran you?
    Going back to stock *GRANT built trans BLOWN w/17k*
  4. #4 Re: Well I done did it guys.(Meth Injection)
    if you spray preblower then for sure run straight meth. that is what im doing right now.
    if you run it after the blower in the LIM it might help you to run a 50/50 mix for added cooling.
  5. #5 Re: Well I done did it guys.(Meth Injection)
    Apr 2009
    Springfield,Va
    Kit was 330$ with the GPForums (GPFalky 10% discount). Plus a solonoid to prevent it from sucking meth out under vacum was 45$ and 4 gallons of premixed meth was 30$.
    Am I going to be hurting anything spaying Devils Own Brew I think its a 48h20/52meth mix though the blower?
  6. #6 Re: Well I done did it guys.(Meth Injection)
    Moore, Oklahoma
    \Plus a solonoid to prevent it from sucking meth out under vacum was 45$
    Hell, you didn't need that solonoid. The DO kit already comes with a one way check valve. You wouldn't of sucked fluid under vacuum with that setup, trust me. I've had great luck with mine....
    Shawn W. Larsen
  7. #7 Re: Well I done did it guys.(Meth Injection)
    Apr 2009
    Springfield,Va
    Good to hear Iron. What about tuning for this setup? Just run it as is incase I run out of meth be on the safe side?
  8. #8 Re: Well I done did it guys.(Meth Injection)
    Apr 2009
    Springfield,Va
    Another thing iron. Are you running this though the stock washer tank? And did you tap into the low level sensor on that? How much meth is left when the low level sensor is triggered?
  9. #9 Re: Well I done did it guys.(Meth Injection)
    Moore, Oklahoma
    With my nozzle size and 50/50 mix on my original Tune my car ran WAY richer.... around 10.5 at WOT. I had to back down the fuel a bit. All I did was use my ICCU and leaned out my fuel a bit to around 11.5-11.7 at WOT. Once I got my fueling where I wanted I dropped down to a 2.9" pulley and raised my timing up +2 degrees at WOT via ICCU. I'm still playing with it somewhat. I need to get my code redone so I can 0 out my ICCU again.
    So with the tune you have now and your alky setup you'll probably run a bit richer which could make you're car slower. You'll need someway to control this to optimize your setup...
    Shawn W. Larsen
  10. #10 Re: Well I done did it guys.(Meth Injection)
    Moore, Oklahoma
    I'm running the DevilOwn Brew which is damn near 50% Meth. I'm also running a DO5 nozzle too. Course my setup is a bit diffferent than yours.
    I'm running Brew because Chance is similiarly modded as I am and I'm shooting for the same times he accoplished with his setup. Hoping I can do it, I need more tuning though. For what little tuning i've actully done, i've very pleased with the results.
    Shawn W. Larsen
  11. #11 Re: Well I done did it guys.(Meth Injection)
    Bastard Reptile's Avatar
    Kansas City, MO
    Some tips to touch on here regarding Methanol.
    On lightly modded cars, start with a small nozzle if you run the brew or washer fluid. Most cars with a 3.4 would probably take a DO3 and be happy. Heavier modded cars will take a DO5 or equal most likely.
    The more potent the mix, the more you're gonna need. Remember, you're just trying to quench the KR, not drown it. It is still water mixed in there, and too much will be like running on a 100% humidity day. Don't over do it, but be careful.
  12. #12 Re: Well I done did it guys.(Meth Injection)
    Moore, Oklahoma
    Quote Originally Posted by Reptile View Post
    Good advice.
    Shawn W. Larsen
  13. #13 Re: Well I done did it guys.(Meth Injection)
    Apr 2009
    Springfield,Va
    I have HPTuners available to me so tuning is not an issue. I play on dropping a pulley size once we get the injection set up. Does the kit come with both the D03 and D05 nozzle?
  14. #14 Re: Well I done did it guys.(Meth Injection)
    i bought mine from a guy who never used it, but all i had in mine were D05s which ended up being right about where i wanted to be with my setup anyway.
  15. #15 Re: Well I done did it guys.(Meth Injection)
    DevilsOwn
    Guest
    Glade everyone likes it. We try hard to make a good kit. Kit comes with a do3 and do5 nozzle. Which should cover a stock gtp power levels up to 400hp. Guys making more power will need to let us know and we can provide larger jets.
  16. #16 Re: Well I done did it guys.(Meth Injection)
    Barksdale AFB, LA
    Do these kits come with detailed installation instructions?
    2009 Subaru Impreza WRX STI
  17. #17 Re: Well I done did it guys.(Meth Injection)
    Moore, Oklahoma
    Quote Originally Posted by Sabrewings View Post
    Yes they do, plus you have more room to hide everything like I did on my GTP. Surely you've seen my write up/pics? If you follow my write up and or the DO instructions, you'll be in good shape. Theres nothing to it really...
    Shawn W. Larsen
  18. #18 Re: Well I done did it guys.(Meth Injection)
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    chris j, that is a beautiful avatar...oh yeah, congrats on the meth kit too!
  19. #19 Re: Well I done did it guys.(Meth Injection)
  20. #20 Re: Well I done did it guys.(Meth Injection)
    Jersey
    I think i just found another mod to add to my list
    16' wrx sti- stock
  1. Meth vs Intercooler
    By Risinnfallen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 02:04 AM
  2. Ethanol injection
    By IndeedSS in forum Off Topic Discussion
    Last Post: 09-03-2008, 09:45 AM
  3. attn: guys who are car salesman or guys who know them
    By shaferz in forum Off Topic Discussion
    Last Post: 03-25-2008, 05:05 PM
