Thread: Well I done did it guys.(Meth Injection)
Results 1 to 20 of 35
  1. #1 Re: Well I done did it guys.(Meth Injection)
    Apr 2009
    Springfield,Va
    Kit was 330$ with the GPForums (GPFalky 10% discount). Plus a solonoid to prevent it from sucking meth out under vacum was 45$ and 4 gallons of premixed meth was 30$.
    Am I going to be hurting anything spaying Devils Own Brew I think its a 48h20/52meth mix though the blower?
  2. #2 Re: Well I done did it guys.(Meth Injection)
    Moore, Oklahoma
    Quote Originally Posted by ChrisJ View Post
    \Plus a solonoid to prevent it from sucking meth out under vacum was 45$
    Hell, you didn't need that solonoid. The DO kit already comes with a one way check valve. You wouldn't of sucked fluid under vacuum with that setup, trust me. I've had great luck with mine....
    Shawn W. Larsen
  3. #3 Re: Well I done did it guys.(Meth Injection)
    Apr 2009
    Springfield,Va
    Good to hear Iron. What about tuning for this setup? Just run it as is incase I run out of meth be on the safe side?
  4. #4 Re: Well I done did it guys.(Meth Injection)
    Apr 2009
    Springfield,Va
    Another thing iron. Are you running this though the stock washer tank? And did you tap into the low level sensor on that? How much meth is left when the low level sensor is triggered?
  5. #5 Re: Well I done did it guys.(Meth Injection)
    Moore, Oklahoma
    Yes, i'm using my stock washer tank. I haven't had mine too low yet but from what I can tell there will be a good amount of fluid left over when the low warning is triggered. If you get to that point, i'd strongly recommend to quit playing and refill your tank. You won't use as much of it as you think, at least I don't and I get on my car all the time.
    Shawn W. Larsen
  6. #6 Re: Well I done did it guys.(Meth Injection)
    Moore, Oklahoma
    With my nozzle size and 50/50 mix on my original Tune my car ran WAY richer.... around 10.5 at WOT. I had to back down the fuel a bit. All I did was use my ICCU and leaned out my fuel a bit to around 11.5-11.7 at WOT. Once I got my fueling where I wanted I dropped down to a 2.9" pulley and raised my timing up +2 degrees at WOT via ICCU. I'm still playing with it somewhat. I need to get my code redone so I can 0 out my ICCU again.
    So with the tune you have now and your alky setup you'll probably run a bit richer which could make you're car slower. You'll need someway to control this to optimize your setup...
    Shawn W. Larsen
  1. Meth vs Intercooler
    By Risinnfallen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 02:04 AM
  2. Ethanol injection
    By IndeedSS in forum Off Topic Discussion
    Last Post: 09-03-2008, 09:45 AM
  3. attn: guys who are car salesman or guys who know them
    By shaferz in forum Off Topic Discussion
    Last Post: 03-25-2008, 05:05 PM
