Thread: Well I done did it guys.(Meth Injection)
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Well I done did it guys.(Meth Injection)
    Bastard Reptile's Avatar
    Kansas City, MO
    Yeah, it actually takes longer to pull the bumper off than it actually does to mount the hardware.
  2. #22 Re: Well I done did it guys.(Meth Injection)
    Apr 2009
    Springfield,Va
    I am right in thinking that the stock washer tank has a Low Level sensor? Was hoping to wire into that for a red led and a green one.
  3. #23 Re: Well I done did it guys.(Meth Injection)
    yes, it has a low level sensor. i opted to get another tank so i could keep my washer fluid working.
  4. #24 Re: Well I done did it guys.(Meth Injection)
    Moore, Oklahoma
    Quote Originally Posted by ChrisJ View Post
    Yes it does. Theres no need to wire in an LED, unless you absolutely want too. When you fluid level goes low in your washer tank, the DIC will pop up a warning on the car hood. Thats all I use.
    I'm using 50/50 so if I absolutely have to clean off my windshield, I can spray some on my windshield without any harm. I hardly ever use this anyway...
    Shawn W. Larsen
  5. #25 Re: Well I done did it guys.(Meth Injection)
    i bet you can use 100% meth to clean the windshield, but it wont work as well as a mix with water.
  6. #26 Re: Well I done did it guys.(Meth Injection)
    Apr 2009
    Springfield,Va
    I'm planning on running the Devil's Brew mix for a while. Got 4 gallons of it coming as well.
  7. #27 Re: Well I done did it guys.(Meth Injection)
    oh my....
    people just dont understand that straight meth is best when run pre-blower....
  8. #28 Re: Well I done did it guys.(Meth Injection)
    Kansas City, MO
    No, it doesn't work that well at all.
    Rain-X works good enough though to just wipe the windshield off.
  9. #29 Re: Well I done did it guys.(Meth Injection)
    Apr 2009
    Springfield,Va
    oh my....
    With the mods listed in my sig would I be better off with straight meth? Or a 50/50 mix? I'm trying to kill some of the detonation as well as up the octane. Little of both.
  10. #30 Re: Well I done did it guys.(Meth Injection)
    let's think about it. what does the blower do? heat up air. therefore, the water doesnt help as much as if you were to do it after the blower where it has a chance to do its thing. it would be best just to use the octane that the straight meth gives you.
    that is my take on it at least.
  11. #31 Re: Well I done did it guys.(Meth Injection)
    DevilsOwn
    Guest
    I would run the 50 / 50 mix . Water is capable of pulling little over 2kj of energy Which is quite abit more than methanol is capable of. Running the nozzle pre blower will cause the liquid to help seal the rotor. Once its thur thats when its goign to really start cooling, same as running post blower. The reason for running the mix is usually the water will evaporte before it hits the cylinders and then you are left with the methanol.
  12. #32 Re: Well I done did it guys.(Meth Injection)
    eh, ill just stick with my straight meth. im liking how it is working so far. way less knock then when i was using washer fluid...as in none.
  13. #33 Re: Well I done did it guys.(Meth Injection)
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    chris j, that is a beautiful avatar...oh yeah, congrats on the meth kit too!
  14. #34 Re: Well I done did it guys.(Meth Injection)
    Apr 2009
    methuen
    Congrats, on the install, now not to thread jack, but can you run nos and meth at the same time? Or is that a no no. Im really interested in this stuff. I am running a 75 dry shot, would it make more power with the meth of just mess things up.
  15. #35 Re: Well I done did it guys.(Meth Injection)
    Quote Originally Posted by 02grandprix View Post
    why not?
  1. Meth vs Intercooler
    By Risinnfallen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 02:04 AM
  2. Ethanol injection
    By IndeedSS in forum Off Topic Discussion
    Last Post: 09-03-2008, 09:45 AM
  3. attn: guys who are car salesman or guys who know them
    By shaferz in forum Off Topic Discussion
    Last Post: 03-25-2008, 05:05 PM
