Thread: Smoke test help for 3800 series 2 engine running lean, HELP PLEASE
Results 1 to 20 of 25
Threaded View
  1. #19 Re: Smoke test help for 3800 series 2 engine running lean, HELP PLEASE
    May 2025
    MI
    So that lasted about a week lol... I used my A.c and everything it was doing started happening again.. rough idle w RPMs going up and down between right below the 1 and up to the middle of the 2,no power behind gas pedal,super long/slow shift from 1st to 2nd and 2nd to 3rd and trying to run hot. I almost couldnt even get the car to start after parking for 15mins for a haircut and comming back out i had to try like 4-5times to get the car to start and stay started. Burning smell back comming from bottom of engine again also. I obviously turned the a.c off once i noticed all this and once it was off it chilled out but what the actual **** is going on here?My mechanic did say my radiator was clogged and my radiator cap was done for but it wasn't letting air into the system. So could it allllll be my radiator this whole time or maybe something else? What else would cause all of this to happen from simply turning on the heat or a/c?
  1. How to tell the difference between a 3800 Series II and Series III engine/ L67 vs L32
    By DoUEvenShift NoBroItsAuto in forum Introductions/Noob Questions
    Last Post: 03-14-2014, 01:12 AM
  2. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  3. 3800 supercharged engine white smoke
    By boostman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 10:04 AM
  4. Engine running lean
    By crd783 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2009, 01:26 AM
  5. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
