Thread: Smoke test help for 3800 series 2 engine running lean, HELP PLEASE
Results 1 to 20 of 24
Threaded View
thefncandyman Smoke test help for 3800... 05-01-2025, 01:53 AM
thefncandyman Re: Smoke test help for 3800... 05-01-2025, 07:23 PM
thefncandyman Re: Smoke test help for 3800... 05-01-2025, 08:35 PM
FordMan77 Re: Smoke test help for 3800... 05-01-2025, 09:13 PM
thefncandyman Re: Smoke test help for 3800... 05-01-2025, 09:33 PM
FordMan77 Re: Smoke test help for 3800... 05-04-2025, 10:20 PM
thefncandyman Re: Smoke test help for 3800... 05-06-2025, 11:02 PM
thefncandyman Re: Smoke test help for 3800... 05-07-2025, 01:04 AM
FordMan77 Re: Smoke test help for 3800... 05-07-2025, 08:12 PM
thefncandyman Re: Smoke test help for 3800... 05-09-2025, 04:31 AM
FordMan77 Re: Smoke test help for 3800... 05-09-2025, 11:37 PM
thefncandyman Re: Smoke test help for 3800... 05-10-2025, 09:23 AM
FordMan77 Re: Smoke test help for 3800... 05-10-2025, 10:21 PM
thefncandyman Re: Smoke test help for 3800... 05-11-2025, 11:08 PM
thefncandyman Re: Smoke test help for 3800... 4 Weeks Ago, 08:46 PM
FordMan77 Re: Smoke test help for 3800... 4 Weeks Ago, 10:47 PM
thefncandyman Re: Smoke test help for 3800... 3 Weeks Ago, 08:15 PM
FordMan77 Re: Smoke test help for 3800... 3 Weeks Ago, 09:26 PM
thefncandyman Re: Smoke test help for 3800... 2 Weeks Ago, 02:36 AM
thefncandyman Re: Smoke test help for 3800... 1 Week Ago, 09:28 PM
FordMan77 Re: Smoke test help for 3800... 1 Week Ago, 11:00 PM
thefncandyman Re: Smoke test help for 3800... 1 Week Ago, 10:17 AM
FordMan77 Re: Smoke test help for 3800... 1 Week Ago, 12:18 AM
thefncandyman Re: Smoke test help for 3800... 1 Week Ago, 05:28 PM
  1. #1 Smoke test help for 3800 series 2 engine running lean, HELP PLEASE
    May 2025
    MI
    I've googled,youtubed and searched EVERYWHERE! I cannot find a vid or pic of WHERE to put the hose w the smoke into my 3800 series 2 engine to run a smoke test. I am NOT a DIYer and i am NOT engine savvy. With that in mind here is my problem.. i have been running lean since January and cant figure out whats wrong but i know it's a oxygen leak. I have the tools to do a smoke test but have NO IDEA where to put the tube the smoke comes out of into my engine to make sure it goes all the way thru the system to tell me where if any there is a oxygen leak. So here is a pic i found on google images w yellow and red writing on it so PLEASE ignore that i circled in blue where i want to hook up the smoke tester too and have learned this is called the throttle body? If i run a smoke test thru this spot will it hit the entireeeee system? If not could someone PLEASSSEEEEE circle in blue whereeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee EXACTLY to put the ****ing hose into. I am not good at stuff w out indepth pictures vids or explanations thus why i am posting here and now. PLEASE HELP ME!
    I have replaced my MAF,MAP,Fuel Pressure regulator,main oxygen sensor on back of engine, and fuel pump. Nothing has fixed or helped.
    I literally just need someone to say hey hook up the smoke machine to this spot and show me exactly where thisss spot it so pleaseeeeeeeeeeeee help me if u can please!!!!!!!!!!!!
    My car is 2001 grand prix 2dr. If theres isn't a random air leak in the system then it's either my EGR Valve,Charcoal canister or its components or my fuel filter.
    Thanks!
    Smoke test help for 3800 series 2 engine running lean, HELP PLEASE Attached Images
  1. How to tell the difference between a 3800 Series II and Series III engine/ L67 vs L32
    By DoUEvenShift NoBroItsAuto in forum Introductions/Noob Questions
    Last Post: 03-14-2014, 01:12 AM
  2. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  3. 3800 supercharged engine white smoke
    By boostman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 10:04 AM
  4. Engine running lean
    By crd783 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2009, 01:26 AM
  5. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
