Thread: Smoke test help for 3800 series 2 engine running lean, HELP PLEASE
Results 1 to 20 of 25
  1. #1 Re: Smoke test help for 3800 series 2 engine running lean, HELP PLEASE
    St. Louis
    Have you ever changed the trans fluid/filter on it? If not you could try that. A trans-go shift kit could alleviate the 1181 max adapt shift issue. You could try disconnecting the electrical plug on top of the transmission, cleaning both sides with electrical cleaner spray and reconnect and see what you get.
    The shake at 50-60mph could be a front wheel hub, cv axle, or both. My brothers 01 GT had both axles get so bad it was shaking the dash. I just installed 2 new hubs and cv axles and all is smooth again.
    What power steering issues do you have? The only super expensive thing is the rack. All other stuff is cheap and easy.
    A trans shop should be able to hook a scanner up to it and command/cycle those shift solenoids I would think. I would call and ask first to be sure that is even possible on an 01.
  2. #2 Re: Smoke test help for 3800 series 2 engine running lean, HELP PLEASE
    May 2025
    MI
    I think it is the rack. About 3 years ago i could put power steering fluid in and it stay in for about 2-3months and slowly leak out. Now my fluid leaks out within a week or less and i never have full power steering it just makes it a tiny bit better. I'm so used to driving it w out power steering i barely notice but where the fluid leaks out is in the boots and a machanic told me id have to replace the rack to stop it so i just never did it and left it as is. I will try calling trans shops and see what they say. I haven't even changed the trans fluid EVER cuz soooo many ppl tell me theres the precious tiny metals in my fluid that i would lose swapping the fluid it could make my trans wayyyyy worse off so i have just kept topping it over ever since i had the car the past 10yrs.. only gotta put any fluid in 1 or 2 times a year if that. I never ever beat on my car or anything like that either so my trans should be good.
    Side note i have a hard start still even after replacing fuel regulator and pump. I doubt the fuel filter could be this problem but coulddd it be possible?
    Since my car started acting like this in the last week of December i was told i was running lean w a oxygen leak... coulddd i be running like this without the lean code or would it ALWAYS have a lean code if i was running lean w fuel or oxygen?
    What made me notice my car acting different was that it was acting as if i had a clogged cat converter and i don't even have a cat i'm str8 piped so i couldn't figure out what the problem was. The main problems i have are hard start,no power what so ever when accelerating (but sometimes it drives completely normal) and the engine running hotish when i sit at a light or in slow traffic i'll go up to halfway hot,on eway im good n stay around 1/4 hot and anytime i accelerate it cools down as well. So i figured cars running lean,making it hot,burning up my coolant and my trans fluid and i figured thats why trans was being weird and the trans only acts weird in 1st gear to 2nd and sometimesss 2nd to 3rd but never on down shift. About 10days after noticing my car starting to get hot w the accelerator weird is when i checked my coolant and it was alllll burnt up like and thick and chunky so i whiped out what i could from radiator coolant input and refilled it and now i gotta refill it once every 10-14days but it only takes 1/4 the bottle of coolant if that and i have no coolant leaks...
    HUGE part i forgot to mention... when this started happening about 2weeks after my gas milage was horrible i was getting about 6mpg literally and ran out of gas on the eway cuz my gas gauge was broken and when i did i looked under the hood in mid january and the bottom of my engine was glowing orange like the hot from a cig. Lots of burning smell comming from there. Once i didn't need to use my heat/defroster anymore this stopped tho and the smell went away also. But this is what made me think the EGR valve. Any input appreciated.
  1. How to tell the difference between a 3800 Series II and Series III engine/ L67 vs L32
    By DoUEvenShift NoBroItsAuto in forum Introductions/Noob Questions
    Last Post: 03-14-2014, 01:12 AM
  2. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  3. 3800 supercharged engine white smoke
    By boostman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 10:04 AM
  4. Engine running lean
    By crd783 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2009, 01:26 AM
  5. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
