Thread: 2004 3.8 #1 cylinder misfire
Results 1 to 20 of 23
  1. #1 Re: 2004 3.8 #1 cylinder misfire
    I'm saying that if #1 is 50psi lower than all the rest, it will cause a misfire code to be thrown.
    The crank learn requires a scan tool that is capable, HP Tuners or an Aeroforce gauge. There are likely other tools that will do it as well. Dealer can perform it too.
  2. #2 Re: 2004 3.8 #1 cylinder misfire
    Mar 2020
    MN
    Today I pulled #1 plug and one other. #1 compression was just as good as the other cyl so I think compression is no longer a question. Fuel rail press is 50psi. So I am stumped. Sooooo, new plugs. wires, Ive eliminated compression, fuel press, new injector, coil, ICM.
    So, I am thinking it has to be a crank relearn like you suggest. My scan tool wont do that, so I think Im just going to have to have her take it into a dealer for that.
    Atleast it has kept her daughter home during these lockdown day of the virus, so parent are happy.
    Thank you all for your help and best wishes in these virus days.
  1. GTP cylinder 4 misfire
    By darin4fun in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2015, 09:02 PM
  2. Cylinder #5 misfire
    By SDGTP99 in forum 5.3L V8 (LS4)
    Last Post: 01-23-2013, 09:43 PM
  3. Cylinder Misfire!
    By AFBCamaro in forum Introductions/Noob Questions
    Last Post: 05-01-2010, 09:52 PM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
