Thread: 2004 3.8 #1 cylinder misfire
Results 1 to 20 of 23
  1. #1 Re: 2004 3.8 #1 cylinder misfire
    The way the pcm reads misfires is based on info from the crank sensor (to know which cylinder) and the knock sensors detecting something being off. Say for example if your compression is low, that could give you a misfire code.
    While you are working on it, if you checked say cylinder 3 compression and it comes up as 180ish, that would point you to maybe a chipped piston or something keeping you from getting good combustion in #1.
    Is this an NA or SC engine?
  2. #2 Re: 2004 3.8 #1 cylinder misfire
    Mar 2020
    MN
    I swapped the coil out with a good one and it stayed right there in #1 cyl. I am going to do a fuel press test tonight although it has the new injector. I am starting to think it might be the ICM board although....This is a wasted spark system correct? If when I swapped #1 and #4 plug wires on the towers, and it was the tower/side for #1 coil that was bad, shouldnt it have moved to #4 cyl?
    I will try doing a compression test again. If it is at 125psi and the rest are at 180 psi, would that be enough of a difference to missfire that hard. Last night, under 1000rpm it barely stayed running.
    Thanks
  3. #3 Re: 2004 3.8 #1 cylinder misfire
    Mar 2020
    MN
    It is not a SC engine. If like billboost said, if a low compression reading tells the crank and knock sensor somethings not right, or if it was a bad coil, wouldnt that also leave #4 misfiring also?
  1. GTP cylinder 4 misfire
    By darin4fun in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2015, 09:02 PM
  2. Cylinder #5 misfire
    By SDGTP99 in forum 5.3L V8 (LS4)
    Last Post: 01-23-2013, 09:43 PM
  3. Cylinder Misfire!
    By AFBCamaro in forum Introductions/Noob Questions
    Last Post: 05-01-2010, 09:52 PM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
