Just an update. The fuel pump is out of it. I have no fuel pressure and I cannot hear it prime. (Took the cover off of it in the trunk) I also checked the harness with a voltmeter and when you turn the key on I get 11.7 volts at the harness. So I know that the system is working to that point. Autozone wants $229 for one but i have found several online for the 60 dollar range with good reviews. I am going to order on off the net and install once it arrives. I also bought a hand pump. I think I will drain as much fuel out as possible and into 5 gallon buckets. Then replace with good fuel and some injector cleaner/sea foam.
Now my issue for the time being falls back to the gear shifter. I am thinking the button you depress is unhooked or malfunctioning. Going to dive into that issue while I wait for a fuel pump to arrive. If anyone has any ideas or suggestions I sure would appreciate them. Again thanks all!
