Quote Originally Posted by tomsteve View Post
id encourage you to not chance the fuel- drop the tank ,empty,and see how it looks inside. it would be wise to change the fuel filter,too.
did you happen to be stepping on the brake pedal when trying to shift?
I have a fuel filter to chage too. Going to check pressure first. Then probably will drain all fuel as noted and check the tank.
