Thread: 1998 GTP Coupe Multiple Issues! Please Help!
Results 1 to 10 of 10
KSGTP22 1998 GTP Coupe Multiple... 03-09-2019, 03:08 PM
markpa Re: 1998 GTP Coupe Multiple... 03-09-2019, 03:15 PM
KSGTP22 Re: 1998 GTP Coupe Multiple... 03-09-2019, 05:49 PM
tomsteve Re: 1998 GTP Coupe Multiple... 03-09-2019, 05:21 PM
KSGTP22 Re: 1998 GTP Coupe Multiple... 03-09-2019, 05:50 PM
Fivefingerdeathpunch Re: 1998 GTP Coupe Multiple... 03-09-2019, 08:05 PM
KSGTP22 Re: 1998 GTP Coupe Multiple... 03-09-2019, 08:26 PM
cheatah faheatah Re: 1998 GTP Coupe Multiple... 03-09-2019, 09:14 PM
KSGTP22 Re: 1998 GTP Coupe Multiple... 03-10-2019, 12:43 PM
tzerilli Re: 1998 GTP Coupe Multiple... 03-11-2019, 10:30 AM
  1. #1 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    I'm pretty sure you need to step on the brake pedal to shift from park. I didn't see that you did that.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  2. #2 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    Mar 2019
    Garden CIty
    I have my shifting issue resolved. The shift knob was raised off of the lever. The U clip was bent and allowed the lever to go higher than it needed to be to properly operate. I pulled the U clip and used channel locks to bend it back properly. I reinstalled it and now we shift properly.
    I have a couple small issues left (window wont roll up) possible bad motor. Going to get my test light out and investigate. Other than that I am just waiting on my new fuel pump.
    Again Thanks everyone!
  3. #3 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    Jul 2017
    macomb mi
    could be a bad window switch my moms friend her passenger window wouldn't go up no matter if you use the driver switch or passenger switch so i assumed it was the motor but then i used a trick i learned from some of the test guys at my work and i took a dewalt battery and connected two wires from the battery to the pins on the motor and sure enough went up and down fine swapped out the switch took me 20 min she told me i saved her from paying a shop $450 so she threw me like $60 i was more than happy haha
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  1. Multiple Issues... maybe
    By DaFrost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2017, 03:05 PM
  2. Multiple Issues
    By aprose in forum General Tech Discussion
    Last Post: 04-23-2012, 01:04 PM
  3. Multiple car issues.
    By suzie in forum General Tech Discussion
    Last Post: 02-25-2011, 07:00 PM
  4. 97 GTP multiple issues
    By Ainrev in forum General Tech Discussion
    Last Post: 02-04-2011, 04:06 PM
  5. multiple issues, help?
    By Brammer in forum General Tech Discussion
    Last Post: 10-04-2010, 03:37 PM
