Thread: SD Headers...OK to put O2 bung in crossover pipe?
Results 1 to 5 of 5
  1. #1 SD Headers...OK to put O2 bung in crossover pipe?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    So, I see that some of the community have welded an O2 bung into the crossover pipe to avoid the interference issues. I'm planning to do this for my next install on an 03 GTP. Are there any practical fueling related issues with regards to only reading exhaust off of one bank?
    I realized that this is only for closed-loop cruising, not WOT, but I don't want to goof the fuel economy on my daily driver.
    Alternatively, does anyone have another suggestion for placement? I've read that distance from the head can be critical.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: SD Headers...OK to put O2 bung in crossover pipe?
    Antioch, IL
    iv ran it in the crossover, scotty runs it, we all have and do tune with it no ill issues. Run it and dont worry about it
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: SD Headers...OK to put O2 bung in crossover pipe?
    th eonly issue is you only reading one side of the engine, that being said if you just going for the standard 3.4 set up you'l be fine. if you were to cam and add more mods then have the bung welded in the dp before the cat. theres a few better places in that same area on the sd headers to re weld the bung in.
    i got the o2 and wb in the dp. Shared album - MrScottydoggs - Google Photos
  4. #4 Re: SD Headers...OK to put O2 bung in crossover pipe?
    Knoxville, TN
    Alright, that's exactly what I needed. I had an O2 bung welded into the crossover, figure I can use that for the upstream narrow band, find a different location to tack in a wideband later, or use the unused upstream hole. I'm assuming that the two banks are going to read close enough. I'm also going to run the downstream narrow band in the normal spot for SD headers.
  5. #5 Re: SD Headers...OK to put O2 bung in crossover pipe?
    Knoxville, TN
    All done, o2 in crossover seems to be working just fine, no issues thus far. Thanks everyone for the feedback!
  1. Crossover pipe leaking?
    By juggernaut56 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2015, 12:11 AM
  2. Replies: 5
    Last Post: 04-10-2015, 10:52 AM
  3. crossover pipe
    By backinblackgtp in forum General Tech Discussion
    Last Post: 04-12-2010, 08:57 PM
  4. ZZP Crossover Pipe
    By SilverGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2009, 04:46 PM
