Thread: Starter or alternator game!
Results 1 to 7 of 7
  1. #1 Starter or alternator game!
    Apr 2011
    North Los Angeles
    Hello everyone, Im having power issues with my 07 base GP. When turning the key my car completely dies out, It'll start out with interior lights and regular beeping etc, when I turn the key EVERYTHING dies. Stays dead for a few seconds or minutes before coming back to life again on it own. Problem started a few days ago and when it did crank it would be prolonged maybe an extra second or two longer making it awkward sounding(crank). I do hear a click when everything dies out and the clock/date resets every time. What say you gurus? Battery was replaced a few months ago. Thanks all!
  2. #2 Re: Starter or alternator game!
    Double check all grounds and battery connections at the battery and starter.
    Another easy test is to stick a digital multi meter directly on the battery. If the voltage just tanks and goes straight to say 2-8 volts the battery has dropped a cell. But if the voltage stays the same and the car still "clicks, loses power upon starting" you have a power/ground problem with likely the cables.
  3. #3 Re: Starter or alternator game!
    Jul 2010
    Coquitlam,BC,Canada
    Sounds like a bad battery. But do a FFDP said. Bad ground or bad alternator may be taking the battery out.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Starter or alternator game!
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I had the same thing happen and didn't realize it was a loose connector until I went to do a voltage drop test. I'd start there. Grab a multi-meter and have some fun!
  5. #5 Re: Starter or alternator game!
    SWPA
    Its neither the starter not the alternator. Alternator has nothing to do with starting the car. It only works once the car is running. The fact that the clock resets means you have a battery problem. Either the battery itself or connections.
  6. #6 Re: Starter or alternator game!
    Apr 2011
    North Los Angeles
    Thanks everyone it was a loose cable.
  7. #7 Re: Starter or alternator game!
    Jan 2015
    Michigan
    Comcast?
  1. Just a little game.
    By Slick2500 in forum Off Topic Discussion
    Last Post: 01-19-2016, 08:43 AM
  2. Keep stock starter set up and add 4 gauge hot wire to starter
    By Jason97GrandprixGT in forum Audio, Security & Visual Electronics
    Last Post: 04-08-2015, 08:21 AM
  3. **Forum Game** Picture Game
    By Empirecrzy241 in forum Off Topic Discussion
    Last Post: 07-03-2013, 02:04 PM
  4. New to this game
    By raw66 in forum Introductions/Noob Questions
    Last Post: 04-07-2010, 11:13 PM
