Thread: SD Headers...OK to put O2 bung in crossover pipe?
Results 1 to 5 of 5
  1. #1 Re: SD Headers...OK to put O2 bung in crossover pipe?
    th eonly issue is you only reading one side of the engine, that being said if you just going for the standard 3.4 set up you'l be fine. if you were to cam and add more mods then have the bung welded in the dp before the cat. theres a few better places in that same area on the sd headers to re weld the bung in.
    i got the o2 and wb in the dp. Shared album - MrScottydoggs - Google Photos
  2. #2 Re: SD Headers...OK to put O2 bung in crossover pipe?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Alright, that's exactly what I needed. I had an O2 bung welded into the crossover, figure I can use that for the upstream narrow band, find a different location to tack in a wideband later, or use the unused upstream hole. I'm assuming that the two banks are going to read close enough. I'm also going to run the downstream narrow band in the normal spot for SD headers.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. Crossover pipe leaking?
    By juggernaut56 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2015, 12:11 AM
  2. Replies: 5
    Last Post: 04-10-2015, 10:52 AM
  3. crossover pipe
    By backinblackgtp in forum General Tech Discussion
    Last Post: 04-12-2010, 08:57 PM
  4. ZZP Crossover Pipe
    By SilverGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2009, 04:46 PM
