Thread: Idle fluctuation and stalling when put into park? Trac light on?
Results 1 to 17 of 17
  1. #1 Idle fluctuation and stalling when put into park? Trac light on?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    For a few months I have been noticing when I put the car in park, most of the time but, not always the idle will drop real low and then come back up and it will teeter tot back and forth about 3 times before coming to sit where its supposed to be. Tonight though I pulled home and put the car in park but left it running and after a few minutes of it idling totally fine out of no where it starts stuttering and then it will recover and it'll go back and forth until it finally stalls unles I give a little push on the gas. I should mention that after it stalled the traction control light was on and not turn off able. I was also watching my wideband the whole time and it was really weird because when it would start stuttering the afr was dropping into the low-mid 12's. Any ideas what this could be?
    Sent from my LG-H918 using Tapatalk
  2. #2 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Oct 2015
    Bump still kind of an issue. It Hasn't stalled recently but ive still been having really weird intermittent idle where it'll go rich and then lean. Etc etc
  3. #3 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Kemmerer, Wyoming
    sounds like it needs a maf adjustment, probably the tcs is something different.
  4. #4 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Oct 2015
    Quote Originally Posted by SgtMarshal View Post
    Tcs? Torque converter?? Well all the sensors seem to read pretty normal all though i did add the nitrous tb spacer around the same time I started noticing it. What's weird though is how it seems intermittent which is why I don't think its just a vac leak.
  5. #5 Re: Idle fluctuation and stalling when put into park? Trac light on?
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Hm... strange. Maybe the ait sensor since it's getting cold?
    And no codes whatsoever? Have you checked the fuel pressure just to be sure?
  6. #6 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Oct 2015
    Quote Originally Posted by wstefan20 View Post
    It doesnt seen to be the iat, that sensor is also reading normal.
    I haven't checked fuel pressure although I doubt that would be an issue when I can go WOT with no issues.
    My current tune has all the check engine codes turned to no reporting so I have no idea if I have any. Ill reflash a tune tomorrow so I can get the reporting back.
  7. #7 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Kemmerer, Wyoming
    traction control system
    edit for more info:
    mine does the same thing, except the rpm's dont drop down very low, I can watch the afr go rich and the idle will get rough.
  8. #8 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Oct 2015
    edit for more info:
    Its not supposed to do that though right? Maybe the car doesn't like having the plugs gapped so small. I read somewhere that a smaller plug gap can cause a rough idle?
  9. #9 Re: Idle fluctuation and stalling when put into park? Trac light on?
    my top swap hated a spark plug small gap. 0.50 works best for me. felt like the engine was misfiring all over the place, idled ok tho.
  10. #10 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Aug 2017
    Raytown, MO
    I've heard a malfunctioning abs module can sometimes cause erratic rpm like this because it is a pass through for the vss data. I'd be curious to know if there are any abs codes, and if not, what the live speed sensor from each wheel looked like.
    When I had a problem with my module, one wheel would bounce from 0 to 80 all over the place and my traction control and abs would go haywire!
    Probably not the problem, but I'm just curious why the abs light is on.
  11. #11 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Mar 2017
    Internet
    start engine.. lift hood...tap maf with finger. Anything different happen? If yes.. time for maf
  12. #12 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Oct 2015
    Well I regappes my plugs at .35 for the nitrous. It seems to run perfectly fine in normal cruising at wot situations.
  13. #13 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Oct 2015
    Quote Originally Posted by BillBooost37 View Post
    Ill try that when I get off work. I have 2 spare maf if that's the problem.
  14. #14 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Mar 2017
    Internet
    Whenever I had a similar issue..I'd pop the hood, tap and presto I knew what the issue was.
  15. #15 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Oct 2015
    Well the abs light isn't on. Only the Trac off light. Although I havent had that happen for a while and it only happened if the car actually stalled.
  16. #16 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Aug 2017
    Raytown, MO
    Quote Originally Posted by suitercrew View Post
    Interesting... if you end up needing a maf sensor though, I've got a spare oem one lying around here somewhere... that is if I can find it...
  17. #17 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Oct 2015
    Just to update the SOLUTION was replacing the upstream o2 sensor for the 3rd time in a couple months. Never ever buy bosch oxygen sensor.
    Sent from my LG-D851 using Tapatalk
  1. stalling at idle
    By richduty455 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2013, 03:58 PM
  2. Car stalling at idle?
    By StainedBedSheets in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2012, 02:13 PM
  3. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  4. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  5. stalling and bad idle.....
    By kingd44 in forum General Tech Discussion
    Last Post: 10-09-2008, 07:27 PM
