Thread: Weird Radio/DIC Range Quesstion
Results 1 to 2 of 2
  1. #1 Weird Radio/DIC Range Quesstion
    Sep 2017
    IL
    Hey all,
    I recently picked up a 2002 GTP. It's having some goofy issues with the Radio and the DIC.
    Firstly, the radio. Intially it was intermittent. Now it's most of the time. The radio display is malfunctioning. It simply shows what appears to be 3 upside down F'S... Seems to work okay, but can't tell where I am based on the display.
    Next, the DIC. The range is on the DIC does not match the fuel gauge. Not even close. You can reset, but it just bounces all over. After a fill up, it went to 350 miles range, then dropped to zero after I reset it, then it trickled up to about 220 and just stayed there. It seems to be quite erratic.
    Both of these issues started about the same time, which makes me wonder if they are related.
    Thanks,
  2. #2 Re: Weird Radio/DIC Range Quesstion
    The Boss Iceman6669's Avatar
    Jun 2011
    The display on the stereo is quite common to crap out on guys. The DIC issue you are having sounds like it might be normal. The distance till empty amount is based on the DIC current MPG readout. So when you reset it, it starts all over again.
    2011 F-150 Yote powered
  1. GTP AFR Range?
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2013, 10:23 PM
  2. What do low range mean???
    By Pierre in forum General Tech Discussion
    Last Post: 04-02-2013, 10:43 AM
  3. New sub box...where'd my range go?
    By Sven the Sexman in forum Audio, Security & Visual Electronics
    Last Post: 09-02-2012, 07:11 PM
  4. range rover
    By Davisgtp in forum Off Topic Discussion
    Last Post: 03-15-2010, 07:34 PM
  5. Bad MAP??? What should the range be?
    By l67fiero in forum PCM Tuning
    Last Post: 08-14-2009, 01:54 PM
