Thread: Idle fluctuation and stalling when put into park? Trac light on?
Results 1 to 17 of 17
  1. #1 Re: Idle fluctuation and stalling when put into park? Trac light on?
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I've heard a malfunctioning abs module can sometimes cause erratic rpm like this because it is a pass through for the vss data. I'd be curious to know if there are any abs codes, and if not, what the live speed sensor from each wheel looked like.
    When I had a problem with my module, one wheel would bounce from 0 to 80 all over the place and my traction control and abs would go haywire!
    Probably not the problem, but I'm just curious why the abs light is on.
  2. #2 Re: Idle fluctuation and stalling when put into park? Trac light on?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Quote Originally Posted by wstefan20 View Post
    Well the abs light isn't on. Only the Trac off light. Although I havent had that happen for a while and it only happened if the car actually stalled.
    Sent from my LG-H918 using Tapatalk
  3. #3 Re: Idle fluctuation and stalling when put into park? Trac light on?
    Aug 2017
    Raytown, MO
    Quote Originally Posted by suitercrew View Post
    Interesting... if you end up needing a maf sensor though, I've got a spare oem one lying around here somewhere... that is if I can find it...
  1. stalling at idle
    By richduty455 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2013, 03:58 PM
  2. Car stalling at idle?
    By StainedBedSheets in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2012, 02:13 PM
  3. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  4. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  5. stalling and bad idle.....
    By kingd44 in forum General Tech Discussion
    Last Post: 10-09-2008, 07:27 PM
