Quote Originally Posted by GTPandGXPand Z28 View Post
mines is starting to do the same thing unless its because my battery was weak..
Best way to check is to do a visual inspection if you're concerned. It will usually only break at one of the connectors, either on the steering wheel or the shift selector. An easy way to check is to grab a continuity meter and probe both pins. It will tell you if there's any breaks in the line.
