Thread: Coolant leak
Results 1 to 3 of 3
  1. #1 Coolant leak
    Nov 2017
    AR
    Hey guys so I went outside this morning to go to work and saw a trail of liquid going out the front of my car on the driveway and I knew something was wrong but I had to go to work so on the way it was getting way hotter than normal but I made it. Then before I left work I filled it up with coolant and made it like a mile and it started overheating so I pulled over and let it cool down and then got it home luckily. After jacking it up it seems like the leak is coming from drivers side bottom corner.. Which makes me think my drain plug is leaking.. Do you think I could be right? It seems like that's the only thing it could be. Any advice would really help me thank y'all
    Sent from my SM-S920L using Tapatalk
  2. #2 Re: Coolant leak
    HUDSON
    Open the hood, start it up and watch as it warms up and look for the leak.
  3. #3 Re: Coolant leak
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    When I'm feeling lazy, I use coolant uv dye, light, and glasses. Never failed to spot an external leak. Easiest if engine is relatively clean to begin with. Good luck
  1. Small coolant leak turned into a large coolant leak
    By DreamerGT in forum General Tech Discussion
    Last Post: 09-23-2016, 11:00 AM
  2. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  3. Coolant leak
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 06-26-2013, 11:19 AM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. My new coolant leak
    By Taz Magister in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2011, 08:31 AM
