Thread: Ignition will not turn to start position
Results 1 to 8 of 8
  1. #1 Ignition will not turn to start position
    Aug 2011
    oshawa
    I put the key in the ignition, but it happens to be locked and will not turn at all. The wheel itself is in the lock position too, anyone have this problem?
  2. #2 Re: Ignition will not turn to start position
    try to turn the wheel, jiggle it back and fourth while trying to turn the key. sometimes they tend to lock up the whole assembly if the wheels are being held like on a hill while the front wheels are turned, its all about the wheel lock, ive had this happen to other cars in the past.
  3. #3 Re: Ignition will not turn to start position
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Happens quite a bit to me. +1 on Scottydoggs idea. Works for me all the time.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  4. #4 Re: Ignition will not turn to start position
    Aug 2011
    oshawa
    tried wiggling steering wheel but had a problem getting key out previously then all of a sudden they wont turn now
  5. #5 Re: Ignition will not turn to start position
    Aug 2011
    oshawa
    The wheel is locked tight and will not even budge, along with the ignition
  6. #6 Re: Ignition will not turn to start position
    can you feel the wheel turn at all? just a little bit, some times you need to push it hard to one side or the other and then try to turn the key.
    ive never had a gp wheel off, but they used to have a slide bolt that went into holes in the wheel and locked it, if the cars wheels were turned or on hill putting pressure on the steering wheel the key would not turn till you turned the wheel off the lock so it would be free to slide back out of the wheel.
    are you on flat ground with the wheels straight?
    could try to jack the front end up, that may loosen up the lock in the steering wheel.
  7. #7 Re: Ignition will not turn to start position
    Aug 2011
    oshawa
    thanks i will try this and get back to you!
  8. #8 Re: Ignition will not turn to start position
    Aug 2011
    oshawa
    no luck , its like seized up
  1. 97 GP GT ignition key wont turn back after start...
    By AREED in forum General Tech Discussion
    Last Post: 12-23-2010, 09:07 AM
  2. Replaced Crankshaft position sensor, now won't start
    By 03grandprix in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-05-2010, 09:22 AM
  3. Ignition stuck in OFF position
    By chilipepperpizza in forum General Tech Discussion
    Last Post: 06-29-2010, 07:25 PM
  4. 2001 Grand Prix ignition off position adjustment
    By davejt in forum Introductions/Noob Questions
    Last Post: 06-16-2010, 11:35 PM
  5. 2001 Grand Prix ignition switch position
    By davejt in forum General Tech Discussion
    Last Post: 06-15-2010, 11:07 PM
