Thread: coolant leak drivers side behind engine (pic now)
Results 1 to 20 of 28
Threaded View
  1. #1 coolant leak drivers side behind engine (pic now)
    GT Level Member RedneckGTP's Avatar
    Oct 2012
    Chelsea, MI
    So, I am starting a new thread for my coolant issue... Swore I had it fixed. new water pump/coolant elbows/upper heater core fittings.
    Everything seemed fine last night and this morning. I got home tonight and noticed antifreeze PUDDLE more towards the drivers side. ?! I cannot see any dripping/leaking from above anywhere. The passenger side of the engine where I did all the work is not leaking. it appears to be coming from the transmission/engine meet up area and hitting the oil pan and dripping off the oil pan lip from about an inch away from the flywheel/flex plate. it does also seem to be dripping off the engine higher up somehow and hitting the transmission pan as well in about the same area. however, shinning a light up in between the trans and oil pan/block, the block appears to be dry. (not much room to get in there with anything to see real good).
    my fear is head gasket. my hope is a LIM. but I should be able to see that up top right?! anything else I am missing or not thinking of?!
  1. big oil leak on front cover side of engine
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2012, 05:17 PM
  2. 2004 GT2 Coolant Leak on Passenger Side
    By apok in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2011, 10:14 PM
  3. need help figuring out how to replace drivers side engine bracket
    By Dmagz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2011, 11:32 PM
  4. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  5. coolant leak on passenger side under car.
    By Teardrop in forum General Tech Discussion
    Last Post: 09-07-2010, 03:42 AM
