Thread: coolant leak drivers side behind engine (pic now)
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: coolant leak drivers side behind engine (pic now)
    GT Level Member RedneckGTP's Avatar
    Oct 2012
    Chelsea, MI
    I pulled the dust sheild off the trans and that didnt help a bit. all I can see is the thing spinning. no obvious wetness or pooling. I can still see the back of the block and the freeze plugs and it looks dry as can be but still have this dripping going on. I sure would hate to pull the damn thing out and it end up being something stupid. although it would make the header install EASY!
  2. #22 Re: coolant leak drivers side behind engine (pic now)
    hit the parts store and buy a rad dye leak kit. you add like 10 drops to the rad, drive around for a bit. then with a some yellow glasses and a black light you can see the trail of coolant. some dont need the glasses or light. see what they sell.
    if they dont have the dye kit
    , then rent a coolant pressure tester, it fit the rad where the cap would go and you pump it up to 18 psi, its got a hand pump on it like bike tire pump. then watch for the leak, the pump shows pressure and you'll see it drop if its leaking, and this will force it to leak making it easier to find when the engine is cold.
  3. #23 Re: coolant leak drivers side behind engine (pic now)
    Oct 2012
    Chelsea, MI
    yeah, probably could maybe hear it to if the car isnt running. that is a good idea. I am familiar with them just hadnt thought about it. Ill see if my dad has one tomorrow. if not ill see about renting one.
    that is one thing I dont have.
  4. #24 Re: coolant leak drivers side behind engine (pic now)
    Oct 2017
    Lafayette, La
    My car is doing the same exact thing did you ever find out where the leak was coming from exactly ?
  5. #25 Re: coolant leak drivers side behind engine (pic now)
    Oct 2017
    Lafayette, La
    I found my leak
  6. #26 Re: coolant leak drivers side behind engine (pic now)
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    How's the storm situation looking down there ?
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  7. #27 Re: coolant leak drivers side behind engine (pic now)
    Oct 2017
    Lafayette, La
    We will be ok on this end. Just a few scattered showers, but to the east of me New Orleans, Mississippi, AL. They could be in for it.
  8. #28 Re: coolant leak drivers side behind engine (pic now)
    May 2016
    Rouge Island
    Cool for you . Thanks, man.
  1. big oil leak on front cover side of engine
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2012, 05:17 PM
  2. 2004 GT2 Coolant Leak on Passenger Side
    By apok in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2011, 10:14 PM
  3. need help figuring out how to replace drivers side engine bracket
    By Dmagz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2011, 11:32 PM
  4. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  5. coolant leak on passenger side under car.
    By Teardrop in forum General Tech Discussion
    Last Post: 09-07-2010, 03:42 AM
