Thread: coolant leak on passenger side under car.
Results 1 to 3 of 3
  1. #1 coolant leak on passenger side under car.
    SE Level Member Teardrop's Avatar
    Indiana
    1994 GTP 3.4
    Doesn't seem to be leaking into the cabin. Quite a minute leak, just enough to see a few drops when parked, after driving.
    I crawled under the car, looked around, and it is making the most mess on the passenger side rear of the sub-frame.
    The heater hose on the passenger side doesn't seem to be wet as much of it as I could see from the water pump to about the middle of the tube where it is close to the rear firewall. I cannot see where it even connects to the heater core, however, going that far to the passenger side, wouldn't it leak somewhere in the middle?
    I cannot see much of anything so I might where could the coolant be leaking possibly that would find it's way to the rear passenger side subframe? Am I missing something?
    Thanks.
    94 Grand Prix GTP, 3.4
  2. #2 Re: coolant leak on passenger side under car.
    Indiana
    Quote Originally Posted by pacothetaco View Post
    lower coolant elbow maybe.
    Where might I find that? Is it like a connection? Without pulling the plenum AGAIN, I can't see much of anything.
    My big concern is that it will rupture. I might add that it seems worse when I run the heater (yeah it is cooler at night now.)
  3. #3 Re: coolant leak on passenger side under car.
    GTX Level Member cerick08GP's Avatar
    After reading your first post my first thought was the coolant elbows also.
    My guess is the #1 elbow. Hopely they are in about the same spot on your engine.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  1. Passenger side water leak
    By Perry125 in forum General Tech Discussion
    Last Post: 07-08-2010, 11:46 PM
  2. passenger side leak
    By Thut420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-22-2009, 11:26 AM
  3. Passenger side headlamp...
    By WayneG99 in forum General Tech Discussion
    Last Post: 09-25-2009, 06:30 AM
  4. "Fixed" the passenger side water leak, still wet!
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 07-24-2008, 06:28 PM
