Thread: SLP Powerflo Install Issues. (Solved)
Results 1 to 10 of 10
  1. #1 SLP Powerflo Install Issues. (Solved)
    Pennsylvania
    I think I got it, man is it really loud though. It sounds good, but its just way too loud.
    All the reviews said it needs a resonator and they're all right. Hopefully that tones it down, I'll be so disappointed if it's still so obnoxious.
  2. #2 Re: SLP Powerflo Install Issues. (Solved)
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    They used to sell SLP's kit under "Loudmouth" name.
    I've been looking at some. Vibrant ultra quiet are supposed to be alright on a GP. There's cheaper options tho.
  3. #3 Re: SLP Powerflo Install Issues. (Solved)
    Nov 2012
    Madison
    I have had a SLP loudmouth catback since 08....it's loud when the car isn't even running.
    I did put a Magnaflow resonator on 2 years ago and it tamed it some.
    My muffler shop guy said it would always be loud with "those" on it. They do look nice though.
  4. #4 Re: SLP Powerflo Install Issues. (Solved)
    i heard a slp cat back on a stage 3 gsx regal a while back in person, why i went with a stock replacement off ebay. it sounded worse than the you tube vids out there. fart, pop, raspberry sounds. not my cup of tea at all.
  5. #5 Re: SLP Powerflo Install Issues. (Solved)
    Pennsylvania
    Well, since I'm already in this deep I might as well see if I can fix it to my taste. Right now it's just a cat into a straight pipe to the mufflers.
    So as for a resonator vs a glasspack, I see some people arguing that they're the same thing, some say they're totally different in what they do.
    Which one will tone it down more? From my reading it seems a good resonator will quiet the volume and drone while filtering out some of the higher noise to leave behind a lower, nicer sound. So is it true that, in this case, the longer/bigger the better? Like magnaflow has 3"-7" round ones, from like 20"-27" long. So I feel like I should get the longest one I can fit.
    I already bought a magnaflow glasspack in anticipation of this, but now I'm thinking it's not going to be enough and I should just get my $23 back, then spend a little more on a resonator.
    Or maybe I should go to advance or something and see if I can find a 2.5" walker res... something designed to be factory which I think would probably end up being the quietest... what about zzp' whisper res they show?
  6. #6 Re: SLP Powerflo Install Issues. (Solved)
    May 2016
    MN
    I don't know if resonators and mufflers are the same. There's different internal designs when only looking at inlet/outlet size.
    Been reading too. It looks like it's a shot in the dark just from so many choices. To add to any confusion, people even try 2 resonators one after the other.
    My direction is also toward the longest that'll fit. Diameter of the muffler/case could be an issue for ground clearance. Dunno how much is too much there, but it looks like 6" might be alright. (2005 GP)
    Cost, do I get a cheap one and hope it does ok? Or, try and get a better one that might outlast my stock mufflers to use later?
  7. #7 Re: SLP Powerflo Install Issues. (Solved)
    Nov 2012
    Madison
    I have an old school father/son shop I go to.
    They hooked me up with what would be the best in my situation.
    Didn't cost a fortune either, like 125 welded.
    Get as big a resonator as fits and you will be happy.
    All 3800s sound like ass no matter whats on the pipe unless maybe big cam and turbo.
    But hell we all know that.
    Any muffler including stock sounds like crap noise just at different frequencies.
  8. #8 Re: SLP Powerflo Install Issues. (Solved)
    ^especially at 2000-2500RPMs when freeway cruising. IMO sounds like a bunch of gators having butt-sex.
    stock mufflers is the best sounding IMO when paired with headers and cat-deleted (because it's quieter lol).
  9. #9 Re: SLP Powerflo Install Issues. (Solved)
    Pennsylvania
    Well guys, I got the glasspack in and I drove it around last night and today. It doesn't sound terrible. It's way better than without the glasspack... tolerable even, but it's still a bit too loud and droney for my taste. It sounds like a riced out civic, just a little deeper toned.
    I like the exhaust to have some gurgle to it, and the stock setup sounded good to me, I just thought this would be that plus a little volume. This is just like one flat bass note that changes volume with rpm.
    I think I'm gunna try to sell this off to recoup some money and then get another resonator to reuse with my stock mufflers. The res was the only rottted part.
    One weird thing is that I noticed a lot more kr on my aeroforce now... I wonder if the vibration is setting off the sensor or something.
    Oh well, thanks guys.
  10. #10 Re: SLP Powerflo Install Issues. (Solved)
    May 2016
    MN
    Tough break, man. Someone will take it off your hands.
    Before I bought kits for my old cars, I heard SLP on a car around town. Tried Dynomax too. I liked Borla kit best, but it's expensive.
    This time doin' it like you might and cutting out old resonator.
  1. Issues with SLP Powerflo install.....Common?
    By rodguezsciii in forum General Tech Discussion
    Last Post: 03-24-2013, 09:17 PM
  2. I got some serious issues following zzp 350 pump install
    By shawnschuldt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2012, 01:54 PM
  3. header install issues
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2012, 10:33 AM
  4. SLP PowerFlo Exhaust 04+
    By Jcal1120 in forum General Tech Discussion
    Last Post: 10-25-2010, 09:46 AM
  5. SLP Powerflo Exhaust
    By 04gpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2009, 05:46 PM
