well like the title says im having some issues after my header install. I bought the ssac headers, had no trouble removing the old manifolds, and all that seeing as the motor was rebuilt not to long ago. The header install went pretty decent and im happy with the fitment. the front 02 clears the firewall great, no issues near the swaybar, and only had to do a little tweaking to get the front off the radiator fan cover. After the install i went for a test drive and im getting sputtering like a miss at anything over 1/2 throttle. Ive checked all over no vaccum lines undone that i can see, i extended the front 02 harness and that seems alright. Im getting a p0300 code with flashing at moderate throttle. The one thing i did notice however is i forgot a bolt from the rear header into the egr tube. would this be something to cause this? Also I left the plug in the rear 02 socket until i can get the old sensor out. if anyone has any thoughts id appreciate it thanks in advance
Another thing i noticed was when i first started to tear into the motor there was a lot of water sitting in the deep parts of the intake manifold, and by the injectors. Ive got the sd hood and its been raining a lot lately, so this could potentially be something but it seems like it wouldve evaporated by now.
