Thread: Driving to work tomorrow with one poly mount. Help?
Results 1 to 14 of 14
  1. #1 Driving to work tomorrow with one poly mount. Help?
    Mar 2017
    Pacific Wonderland
    Was going to flip the poly mounts today but noticed that whatever tech that took these off before used a different size bolt than stock on one of the mounts. It has a 5/8 head instead of the 15m? on the other side. Unfortunately, now I can't​ get the blasted thing off to put the dog bone back on. Do I just get another mount from a junkyard? I don't even see how to get this one off. Anyone know the right size for the bolt? If I can get this one off I don't ever wanna put it back on. I gotta stop doing these sorta things on Sunday nights
  2. #2 Re: Driving to work tomorrow with one poly mount. Help?
    Mar 2017
    Internet
    Did you consider an adjustable wrench?
  3. #3 Re: Driving to work tomorrow with one poly mount. Help?
    Mar 2017
    Pacific Wonderland
    It's jammed so tight. I had the correct size wrench and was turning it, but it won't go anywhere. I could feel heat coming from all the friction as it turned. Tried tugging it out with a clamp too. It's not moving.
  4. #4 Re: Driving to work tomorrow with one poly mount. Help?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Can you cut the head off bolt?
  5. #5 Re: Driving to work tomorrow with one poly mount. Help?
    Mar 2017
    Pacific Wonderland
    https://imgur.com/xPoGBRC.jpg
    I didn't actually flip the mount yet. It started twisting on it's own when I tried pulling the bolt out. I didn't even use WD-40 cuz apparently I'm out and didn't realize it. I've just been yanking on it and feel like I'm gonna break something.
  6. #6 Re: Driving to work tomorrow with one poly mount. Help?
    May 2016
    MN
    Oh, I see it. Well, if you need to get to work just slap it back on. Should hold fine ..unless you're saying it won't go back on.
    Then that's a problem.
  7. #7 Re: Driving to work tomorrow with one poly mount. Help?
    Mar 2017
    Pacific Wonderland
    I can't put the dogbone on cuz the bolt won't come out.
  8. #8 Re: Driving to work tomorrow with one poly mount. Help?
    Sep 2015
    Cheyenne, WY
    Use acetone or torch the rubber mount to get it out.
    2007 Antique Bronze Metalic Grand Prix GT...bone stock.
  9. #9 Re: Driving to work tomorrow with one poly mount. Help?
    Mar 2017
    Pacific Wonderland
    A torch won't melt it?
  10. #10 Re: Driving to work tomorrow with one poly mount. Help?
    Donating Users
    Kansas City
    I only ran the left dog bone with the coil pack anyways with poly lower engine/trans mounts. It never moved.
    My bet is: Go to the junkyard. Quit trying to flip the mounts and get a set of $40 polys.
    Press em in, done and done.
    2012 Buick Regal Premium1 Turbo - White Diamond Tri-coat - 20% Tint - 5k HID Head/Fog Lights - ZZP CAI
  11. #11 Re: Driving to work tomorrow with one poly mount. Help?
    GTP Level Member buickman104's Avatar
    NYC
    Google Grand Prix GXP engine bay. The 303 V8 powered Front wheel drive Grand Prix only runs with one dog bone. You'll be fine with one.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  12. #12 Re: Driving to work tomorrow with one poly mount. Help?
    Kemmerer, Wyoming
    and it's not even poly, it's rubber just like the oem in all other W-Bodies, plus the engine makes 50 more hp and maybe 70 more tq lbs. the LS4 is like 70 lbs heavier than the L67, so you will be fine driving it.
  13. #13 Re: Driving to work tomorrow with one poly mount. Help?
    put the nut on at the end of the threads there to protect them, then smack it with a hammer firmly and squarely.
  14. #14 Re: Driving to work tomorrow with one poly mount. Help?
    Mar 2017
    Pacific Wonderland
    Guy at work told me that hammer trick. I'll try it tonight. Thanks for all the help guys.
  1. ZZP poly trans mount
    By klimtrack in forum For Sale - Parts
    Last Post: 11-30-2016, 10:49 AM
  2. Getting more work done at body shop tomorrow
    By Hardonyomom in forum Visual/Body Modifications
    Last Post: 01-20-2015, 02:05 PM
  3. Poly mount discussion
    By clarks2002gtp in forum Introductions/Noob Questions
    Last Post: 04-08-2014, 06:13 PM
  4. work on the car starts tomorrow
    By Poil336 in forum Off Topic Discussion
    Last Post: 03-20-2010, 12:31 AM
