Thread: Clunking noise, mounts suspected. Help ID this pic?
Results 1 to 8 of 8
  1. #1 Clunking noise, mounts suspected. Help ID this pic?
    Feb 2017
    Florida, Palm Bay
    Stock 07 Grand Prix V6 NA. Getting clunk noise when turning car off/on sometimes. Clunks when shifting into reverse. Im also able to hand rock the engine a bit. Doesnt clunk when nose is up on slight incline. Based on searchin the forum it is likely a mount.
    Checked the car a bit while dropping trans pan for refill, noticed this bent looking piece, I think its a mount. http://imgur.com/a/LmnkZ
    Is there supposed to be that bent bit in there like that?
  2. #2 Re: Clunking noise, mounts suspected. Help ID this pic?
    Mar 2017
    St Louis
    Having the same problem with my 2000, going to check it out tomorrow. I know the mounts are a pretty common problem givin the description you gave. Ill let you know what i find out.
  3. #3 Re: Clunking noise, mounts suspected. Help ID this pic?
    Feb 2017
    Florida, Palm Bay
    Quote Originally Posted by AustinRay96 View Post
    Cheers, been running some google image searches but unable to locate any shots showing the exposed wheel well area to compare it to mine.
  4. #4 Re: Clunking noise, mounts suspected. Help ID this pic?
    Feb 2017
    Florida, Palm Bay
    Just found the part, took awhile because a majority of the trans mounts I was finding for sale online had a different design that has a plate/shield over the mount which made it appear different to me.
    Anyways, it is definitely broken or at least the pin is bent, it should look like this http://imgur.com/a/Epa45
  5. #5 Re: Clunking noise, mounts suspected. Help ID this pic?
    you need both lower engine mounts, tranny and engine. thats your clunk. see that tab pushed up int h etranny mount, the rubber under it is gone.
    pop the hood, shift from P to D to R, watch the engine, i bet it flops back and fourth a good 4 inches, if you got oil leaks this also helps kill the engine mount, when that mount is shot the engine will twist in the bay. and clunk.
    this is the first engien mount i went through, did everything im described above
    round 2. i made the mounts solid. this new mount aint failed me yet, but ive also fixed my leaks.
    trans mount, you got the regal mount there, some say its better, i dont care for it, and i got a regal. i made the gtp mount solid as well.
  6. #6 Re: Clunking noise, mounts suspected. Help ID this pic?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    There are solid rubber options.
    Transmission mount-
    WESTAR EM2712S Info
    Solid Mount
    Choose: [Regular Inventory] (Only 7 Remaining) ($11.56) [Private Label Package] ($12.17)
    $11.56
    engine mount-
    ANCHOR 2796SR Info
    Front; SOLID RUBBER
    Choose: [Regular Inventory] (Only 3 Remaining) ($14.43) [Private Label Package] (Only 4 Remaining) ($15.36)
    $14.43
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  7. #7 Re: Clunking noise, mounts suspected. Help ID this pic?
    a lot of them so called solid mounts are not solid. most are fluid filled. if you shake them you can hear fluid moving. drilling a hole in them will tell you for sure lol
    mine are drilled, blown out, filled then left to cure for a few days.
  8. #8 Re: Clunking noise, mounts suspected. Help ID this pic?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yes you have to be careful. The parts stores mix them up. The ones I got from rock auto are solid. I tried one from autozone cross referenced and it had fluid like you said.
  1. clunking noise
    By SSGP in forum Introductions/Noob Questions
    Last Post: 12-20-2013, 08:40 PM
  2. Clunking noise
    By Performance nut in forum Brakes/Suspension/Chassis
    Last Post: 01-08-2013, 02:24 PM
  3. clunking noise
    By jessejj79 in forum General Tech Discussion
    Last Post: 02-28-2011, 12:49 PM
  4. Clunking Noise...
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 01-10-2011, 09:17 PM
  5. clunking noise?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-07-2009, 02:55 AM
