Thread: Oil light in dash on and off Oil level OK. 08 Base
Results 1 to 2 of 2
  1. #1 Oil light in dash on and off Oil level OK. 08 Base
    Northern IL
    Got a weird issues that just started on my wife's car. The Oil pressure light on the dash is coming on and off at times. This morning she informed after getting to work it was on about the first 5min of her drive. The oil level was good on it this morning when she left (checked the dip stick). Nothing on the display showing low oil either. The rest of her 30+min drive the light was off. For the first 5 mins of driving there was speeds up to 45mph. No engine noises.
    Not sure if it might be the oil pressure sending unit or the sensor. In looking it seems they are different parts. What might be the best way to check this?
    I do not think this would have anything to do with it. At the same time the car is telling her to check her gas cap. It is tight. Thinking I just need to replace it.
    We are looking to trade this car in in the next month or two. Trying to keep large costs down.
    Thank for your help.
  2. #2 Re: Oil light in dash on and off Oil level OK. 08 Base
    St. Louis
    Check the sending unit itself. Not sure on the 04+ cars, but I know the older ones had an issue with failing internally and letting oil leak into the connector and some failed altogether attempting to empty all the oil from the engine.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. to all who have ever had low oil level light come on...
    By ddw350 in forum General Tech Discussion
    Last Post: 09-30-2013, 10:08 AM
  3. Dash/Raido Resets When Turning - 08 Base Model
    By Nic8524 in forum General Grand Prix Discussion
    Last Post: 05-13-2012, 04:56 PM
  4. Low oil level light
    By 1slo03GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-12-2012, 03:19 PM
  5. 06 base GP- keeping the rear level w/extra weight
    By White Ghost in forum Brakes/Suspension/Chassis
    Last Post: 09-12-2009, 11:12 PM
