Thread: clunking noise
Results 1 to 10 of 10
  1. #1 clunking noise
    Dec 2013
    Leavenworth, KS
    Hey everybody just joined the forum. I got a 04 GTP Comp group and ive had it since the end of june. i love the car and got big plans for it.... but i got a major clunking noise everytime i put it in gear and start to take off or hit the brakes. has anybody else had this issue and if so wat was it. it sounds like its coming from the front drives side. ive replace the strut and mount and the tie rod end and it still does it. what could it be???!???!
  2. #2 Re: clunking noise
    sounds like the motor and tranny mount need to be changed.
    pop the hood, start the car, then watch the engine as you shift it from P to R to D. if its moving more then 2 inches thats your clunk.
  3. #3 Re: clunking noise
    Dec 2012
    Where 4T65E's were born
    Mileage? Any play in the tires at all? If not, check the motor mounts. Could be ball joints or LCA bushings.
    Sold.
  4. #4 Re: clunking noise
    Dec 2013
    Leavenworth, KS
    Its got 121xxx and the motor and trans mounts look good. When you go to shake the motor the whole car moves. And when you shift it into gear and watch the motor its not moving excesively or hard. And my next thing to replace is the ball joint. After i get new tires put on.
  5. #5 Re: clunking noise
    Dec 2012
    Yeah it sounds like ball joints or the lca bushings to me. When you accelerate and brake, it puts a strain in a twisting motion on those parts as they're trying to hold the knuckle perfectly straight. So it may slide one way or another if there's play.
    Sold.
  6. #6 Re: clunking noise
    Dec 2013
    Leavenworth, KS
    Ya i could see that. Ill price the stuff tomorrow when i go to work.
  7. #7 Re: clunking noise
    check the sway bar bushings and end links also. the bushings go bad and clunk over bumps.
  8. #8 Re: clunking noise
    Dec 2013
    Leavenworth, KS
    It only clunks when i put it in gear and go to take off or slow down to a stop. It doesn clunk going over bumbs
  9. #9 Re: clunking noise
    they are worth looking at still, there right there so its easy to see if they are bad.
  10. #10 Re: clunking noise
    Dec 2013
    Leavenworth, KS
    Ya thats true
  1. Clunking noise
    By Performance nut in forum Brakes/Suspension/Chassis
    Last Post: 01-08-2013, 02:24 PM
  2. 2008 GP GXP clunking noise???
    By stewy58 in forum Brakes/Suspension/Chassis
    Last Post: 11-08-2011, 08:43 AM
  3. clunking noise
    By jessejj79 in forum General Tech Discussion
    Last Post: 02-28-2011, 12:49 PM
  4. Clunking Noise...
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 01-10-2011, 09:17 PM
  5. clunking noise?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-07-2009, 02:55 AM
