Thread: Cam install, so many misfires TCC wont lock
Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 163
  1. #61 Re: Cam install, need advice leaking exhaust valve?
    i did a top swap over a year ago now, dont sweat it. not a big deal really. buy new bolts, or head studs. you'll need a degree gauge too if you use tty new bolts. a long breaker bar is a must or a pipe on the end of a short one. i swear you think the bolts are gonna snap when you degree them, you've never made a bolt so tight in your life and not had it snap lol
    you also want to take a old head bolt, cut a groove in the threads on two sides then put it in each head bolt hole in the block and remove it, this cleans the threads out so your tq'ing is proper.
    i used felpro head gaskets too.
  2. #62 Re: Cam install, need advice leaking exhaust valve?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Might as well do both head gaskets right?
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  3. #63 Re: Cam install, need advice leaking exhaust valve?
    and i also sprayed both sides of the head gaskets with that copper gasket spray, hung them on a hook and sprayed 2 coats on both sides and laid them on tacky still.
    not sure if thats really needed but i figured it cant hurt any.
  4. #64 Re: Cam install, need advice leaking exhaust valve?
    Quote Originally Posted by 94GrandPrixSE View Post
    take em both off and you may as well port em lol
  5. #65 Re: Cam install, need advice leaking exhaust valve?
    Nebraska
    How did you clean up the surfaces? Just a razor and brake clean?
  6. #66 Re: Cam install, need advice leaking exhaust valve?
    yup. theres not much to clean off really, some carbon residue and a little old gasket film.
    this was before cleaning/scraping the deck, i was cleaning the piston tops of carbon.
    and the head before cleaning
    all cleaned up. ported, polished. put about 18-20 hrs into them.
    even if you were to just polish them and make then smooth inside is a vast improvement.
  7. #67 Re: Cam install, need advice leaking exhaust valve?
    Buffalo
    Wire wheel. Brake cleaner. Oven cleaner. Rinse repeat Wish I had an easy answer
  8. #68 Re: Cam install, need advice leaking exhaust valve?
    Nebraska
    Where did you get your torque specs and sequence not seeing any write ups.
  9. #69 Re: Cam install, need advice leaking exhaust valve?
    Buffalo
    Start at the inside right hand bolt and work in a X pattern
    the bolts or studs come with the torque specs
  10. #70 Re: Cam install, need advice leaking exhaust valve?
    Buffalo
  11. #71 Re: Cam install, need advice leaking exhaust valve?
  12. #72 Re: Cam install, need advice leaking exhaust valve?
    Impact everything.
  13. #73 Re: Cam install, need advice leaking exhaust valve?
    Nebraska
  14. #74 Re: Cam install, need advice leaking exhaust valve?
    Nebraska
    Looks like I was floating a valve... explains the leak, whats next? other than new valves?
  15. #75 Re: Cam install, need advice leaking exhaust valve?
    hows that spring looking? som-bishh hit the piston.
    needs a valve job at min id think at this point. see if the valve stem is bent too.
  16. #76 Re: Cam install, need advice leaking exhaust valve?
    Kemmerer, Wyoming
    I was wondering what that nick was
  17. #77 Re: Cam install, need advice leaking exhaust valve?
    Nebraska
    Spring got mixed up with the others when I put the 90#s on. The valve looks perfectly straight but it must be bent juuusst enough to cause a leak. So new valves and valve job? Should I mill the heads flat? Alum heads? Lol
  18. #78 Re: Cam install, need advice leaking exhaust valve?
    Kemmerer, Wyoming
    I would consider getting the heads milled, but it will raise the compression ratio, so you might have to run a bigger pulley or higher octane fuel. a valve job for sure.
  19. #79 Re: Cam install, need advice leaking exhaust valve?
    you just installed the cam right? a stock spring should not let the valve hit. cause by the looks of that piston that valve has been messed up for a long time.
    take it too a shop, ask for their recommendation of what to do with it. maybe they will fix the one valve seat. but im sure they would want to do all of them. it maybe best to do both heads too if they say this one needs a full rebuild.
  20. #80 Re: Cam install, need advice leaking exhaust valve?
    Nebraska
    The new cam isn't in yet I was about to put it in when I discovered the leaky valve. How else could it hit the valve?
  1. Getting car ready for the track... Any suggestions?
    By GTPMidknight in forum Track Sessions and Kills
    Last Post: 01-31-2015, 10:44 AM
  2. About ready to cry..PLEASE help
    By TJs97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2013, 09:13 PM
  3. I'm ready to have some fun with a GP
    By Chmanzi in forum Introductions/Noob Questions
    Last Post: 11-25-2009, 11:18 PM
  4. Hey all! Get ready!!
    By 69Fiat in forum Introductions/Noob Questions
    Last Post: 08-09-2009, 11:01 PM
  5. Getting Ready. Any Last Suggestions???
    By kingbrentdwyer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2009, 01:09 PM
cam
