Thread: Cam install, so many misfires TCC wont lock
Page 7 of 9 FirstFirst ... 56789 LastLast
Results 121 to 140 of 163
  1. #121 Re: Cam install, need advice leaking exhaust valve?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    All back together, I ended up using rtv to seal the head studs, recommended by the guy that ported my heads. Runs good turned the idle up to 900 all the time to hopefully save my dampener. My million dollar problem/ question: I have metal dust in my oil, can't see it much on the dipstick but looking in the valve cover, the oil flowing into the valley you can see the the metal dust reflection with a flashlight. Haven't changed the oil yet.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #122 Re: Cam install, metal dust in oil!?!?
    drain oil through a coffee filter or the likes to see if theres really anything in it.
  3. #123 Re: Cam install, metal dust in oil!?!?
    Nebraska
    Right now? Prob has 30 mins of idling on it.
  4. #124 Re: Cam install, metal dust in oil!?!?
    right now! if you think you see stuff, why keep running it? dump oil, check it out asap. change the filter too.
    when i did my engine swap i ran it for about 20 minutes and did a oil change for sh-its and giggles.
  5. #125 Re: Cam install, metal dust in oil!?!?
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Change the oil then go run it up the street. And get on it pretty good. Then check it when you get back. No need to baby a 3800 after a cam change.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  6. #126 Re: Cam install, metal dust in oil!?!?
    Nebraska
    Oil is just very metalic similar to how transmission fluid gets. Super small metal particles, can't find anything I would consider large I strained the oil filter out and a bit of the oil. Also felt my hand around in the pan nothing big. Could it be from the assembly lube or the arp lube for the studs?
  7. #127 Re: Cam install, metal dust in oil!?!?
    could be. still change it, drive it, see what goes on. pretty sure you should be doing a oil change this fast anyways. i would.
  8. #128 Re: Cam install, metal dust in oil!?!?
    Nebraska
    After I dumped the pan there was a few peices of metal looking flakes but they looked like old or new head gasket material but then again I could be in denial lol. Putting new oil in now.
  9. #129 Re: Cam install, metal dust in oil!?!?
    Jan 2013
    Raleigh, NC
    I changed mine after 20 mins or so of driving after my cam install. Then 4000 miles later. It's holding up great 2 years down the road
  10. #130 Re: Cam install, metal dust in oil!?!?
    Nebraska
    Did you have any metalic in your oil?
  11. #131 Re: Cam install, metal dust in oil!?!?
    mine looked like new oil to me. seemed like a waste, but f it, id rather toss 20 bucks in the dirt and be safe.
    all i did was clean and re-gasket the engine, no cam, so no assembly lube was used.
  12. #132 Re: Cam install, metal dust in oil!?!?
    Jan 2013
    Raleigh, NC
    Just the smallest amount. Next oil change, nothing.
  13. #133 Re: Cam install, metal dust in oil!?!?
    Nebraska
    New oil in went for a drive still metalic in oil, maybe a little less this time. No weird noises, what's my worst/ best case senario. I've never see bearings go out with metalic dust always metal shavings.
  14. #134 Re: Cam install, metal dust in oil!?!?
    Jan 2013
    Raleigh, NC
    Best case nothing ever comes of it. You keep driving and nothing goes wrong. Worse case, you got a bad cam, or knicked a cam bearing going in. It that isn't too bad you'll just round off the lobe. If it's really bad, grenade....
  15. #135 Re: Cam install, metal dust in oil!?!?
    Nebraska
    Based on everyone's experience what should I do? Run it or pull it? I'm a gambling man but don't have the experience some of you guys do.
  16. #136 Re: Cam install, metal dust in oil!?!?
    Jan 2013
    Raleigh, NC
    if it truly is just a small amount I would run it.
  17. #137 Re: Cam install, metal dust in oil!?!?
    Nebraska
    If it was a cam bearing wouldn't I have actual shavings?
  18. #138 Re: Cam install, metal dust in oil!?!?
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by 94GrandPrixSE View Post
    Probably. That's why I would run it. It's probably nothing
  19. #139 Re: Cam install, metal dust in oil!?!?
    pic of oil? pull dip stick hold in the sun or a light, take pic.
  20. #140 Re: Cam install, metal dust in oil!?!?
    Buffalo
    There's not really much to break in during a cam swap with roller tip rockers and all but I still change the oil every time after the first run / drive
  1. Getting car ready for the track... Any suggestions?
    By GTPMidknight in forum Track Sessions and Kills
    Last Post: 01-31-2015, 10:44 AM
  2. About ready to cry..PLEASE help
    By TJs97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2013, 09:13 PM
  3. I'm ready to have some fun with a GP
    By Chmanzi in forum Introductions/Noob Questions
    Last Post: 11-25-2009, 11:18 PM
  4. Hey all! Get ready!!
    By 69Fiat in forum Introductions/Noob Questions
    Last Post: 08-09-2009, 11:01 PM
  5. Getting Ready. Any Last Suggestions???
    By kingbrentdwyer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2009, 01:09 PM
cam
