Thread: Cam install, so many misfires TCC wont lock
Page 8 of 9 FirstFirst ... 6789 LastLast
Results 141 to 160 of 163
  1. #141 Re: Cam install, metal dust in oil!?!?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    I found out the assembly lube I used and most assembly lubes use graphite. Did a test with some oil and a pinch of lube sure enough turned metalic. Now this doesn't account for the few bigger peices unless it was foreign or old head gasket. Just going to hope for the best and stay out of high rpm and boost until I'm sure. What rpms do you guys set your idle at with cams? I set mine at 900 but want to preserve the damper as long as possible since I'm running the dampener killer 90#ers.
  2. #142 Re: Cam install, metal dust in oil!?!?
    sounds good then. mystery solved.
  3. #143 Re: Cam install, metal dust in oil!?!?
    drive it.. you'll know quick enough if something is bad.
  4. #144 Re: Cam install, metal dust in oil!?!?
    Buffalo
    Debris gets everywhere when scraping and cleaning. That's why we all say run it and dump it.
  5. #145 Re: Cam install, metal dust in oil!?!?
    True...I gave it a couple min of run time..and dump
  6. #146 Re: Cam install, metal dust in oil!?!?
    Nebraska
    Appreciate the help, no better feeling than having to do everything all over again.
    Cam guys, what rpm did you set your idle at?
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  7. #147 Re: Cam install, metal dust in oil!?!?
    had mine around 800..maybe 1000. It's more of what feels/runs right
  8. #148 Re: Cam install, metal dust in oil!?!?
    Buffalo
    If you want to have best of both worlds, set it low but safe in gear and lower in N only
    so when you want to hear your bumpstick, shift it to N
  9. #149 Re: Cam install, metal dust in oil!?!?
    Nebraska
    It runs ok at 900 but want to save dampener. Bumpstick, I love it. Anyone running 90#ers?
  10. #150 Re: Cam install, metal dust in oil!?!?
    dude..I have an audi. No idea what springs she came with. Fast though
  11. #151 Re: Cam install, metal dust in oil!?!?
    May 2008
    Schuyler, NE
    I ran 90# springs with an xp for awhile. Iirc, I just left idle at stock....maybe raised it 50rpm.
  12. #152 Re: Cam install, metal dust in oil!?!?
    Nebraska
    What did your dampener look like?
  13. #153 Re: Cam install, metal dust in oil!?!?
    May 2008
    Schuyler, NE
    Well, after 30k miles, I swapped to 130# springs. Then, after 20k miles on those, I pulled the chain and dampner....very little wear. Probably equivalent to a stock motor with 150k on it.
  14. #154 Re: Cam install, metal dust in oil!?!?
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by 94GrandPrixSE View Post
    700 rpm
    Cause the sound is half the fun
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  15. #155 Re: Cam install, metal dust in oil!?!?
    Buffalo
    I don't have a dampener.
    When I did it was with s1x and 105s. It looked fine when I took it out
  16. #156 Re: Cam install, metal dust in oil!?!?
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Stock dampener. 90 Springs. VS cam. I idle at 775 rpm. Sounds and idles like stock. On a rebuild I changed oil after first startup, 100 miles, 500 miles, then normal oil changes. Probably overkill but oil is cheap and wanted to make sure any contaminates, ie leftover gasket, assembly lube, dust, dirt, antifreeze, etc, got flushed out.
  17. #157 Re: Cam install, so many misfires TCC wont lock
    Nebraska
    Put some miles on the cam, metallic in oil seems to have faded away. Car sounds great, and scoots right down the road but im chasing this random misfire that I believe is causing my TCC not to lock.
    Im using AL103's gaped at .52. From my research im using the right temp plugs and gap. My coils were fine before the cam install (no misfires). I did notice a small crack where the bolt to the coil bracket but cant imagine that would cause my issue. Cylinders 6 and 4 misfire much more than the others.
    Any advice??
  18. #158 Re: Cam install, so many misfires TCC wont lock
    swap that coil. the crack could be the issue.
  19. #159 Re: Cam install, so many misfires TCC wont lock
    Nebraska
    Will do scotty, is MSD as bad as ive heard?
  20. #160 Re: Cam install, so many misfires TCC wont lock
    Kemmerer, Wyoming
    those plugs only last like 3000-5000 miles, and that gap is bigger than it needs to be, I gap mine to .35.
  1. Getting car ready for the track... Any suggestions?
    By GTPMidknight in forum Track Sessions and Kills
    Last Post: 01-31-2015, 10:44 AM
  2. About ready to cry..PLEASE help
    By TJs97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2013, 09:13 PM
  3. I'm ready to have some fun with a GP
    By Chmanzi in forum Introductions/Noob Questions
    Last Post: 11-25-2009, 11:18 PM
  4. Hey all! Get ready!!
    By 69Fiat in forum Introductions/Noob Questions
    Last Post: 08-09-2009, 11:01 PM
  5. Getting Ready. Any Last Suggestions???
    By kingbrentdwyer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2009, 01:09 PM
cam
