Beats me, take it apart and see if the contacts for the button are bad.
Also when you turn the vehicle on, the traction control is ON. You must hit the button to disable it. So burning the tires off with the button clicked is suppose to happen. No vehicle made has the traction control disabled when you start the car, they all require you to disable it somehow. It's a safety feature.
Well mine is constantly off is what I am getting at. Even when I turn the vehicle on the traction control is off. With traction control on it limits tire spin. With it off it doesn't. I can roast the tires from 1st/2nd and into drive.
So some how the "Saftey feature" is disabled in mine. So not sure if wire is dead/disconnected etc etc or what. Will check to see if button is bad, but was just wondering if it could be something other then a bad button or fuse or something.
