Thread: Traction control wont turn on. Need help
Results 1 to 11 of 11
  1. #1 Traction control wont turn on. Need help
    May 2016
    Canada
    Hey, I need some help. I have a 2000 pontiac GTP. I know when the traction control is off ( with light on ) and abs light on it means a bad hub. But my car has no issues abs light is not on or any other light.
    Only problem I have is when I click the traction control button it wont turn the traction on. It is permanently off which doesn't bother me. Just curious if its a bad fuse,switch or something else that is more major that I have to replace.
    Any help would be appreciated. Thanks.
  2. #2 Re: Traction control wont turn on. Need help
    Does it light up when you first turn the key on?
    Looks into a burnt bulb first.
  3. #3 Re: Traction control wont turn on. Need help
    May 2016
    Canada
    All bulbs work. None burnt out. Switch wont toggle it on or off. I know because I can burn the tires easily with button clicked.
  4. #4 Re: Traction control wont turn on. Need help
    Beats me, take it apart and see if the contacts for the button are bad.
    Also when you turn the vehicle on, the traction control is ON. You must hit the button to disable it. So burning the tires off with the button clicked is suppose to happen. No vehicle made has the traction control disabled when you start the car, they all require you to disable it somehow. It's a safety feature.
  5. #5 Re: Traction control wont turn on. Need help
    May 2016
    Canada
    Well mine is constantly off is what I am getting at. Even when I turn the vehicle on the traction control is off. With traction control on it limits tire spin. With it off it doesn't. I can roast the tires from 1st/2nd and into drive.
    So some how the "Saftey feature" is disabled in mine. So not sure if wire is dead/disconnected etc etc or what. Will check to see if button is bad, but was just wondering if it could be something other then a bad button or fuse or something.
  6. #6 Re: Traction control wont turn on. Need help
    best to find a shop that can scan abs codes. t/c light on all the time is abs related, the code that is stored in the bcm is the path to repairing it, or your just guessing and tossing money at it.
  7. #7 Re: Traction control wont turn on. Need help
    In that case I'd find a scanner that can read ABS and wheel speed sensor codes just to see if anything pops up.
  8. #8 Re: Traction control wont turn on. Need help
    May 2016
    Canada
    Appreciate the help. Going to go grab an OBD2 reader today that can scan it.
  9. #9 Re: Traction control wont turn on. Need help
    make sure its a abs scanner, the cheap code reader will not do abs codes. abs scanners start at a $100 or more.
    if you stop by a few shops you'll find one that has a real scanner, if lucky they'll scan it for free. most will charge you 20 or 30 bucks as a diag fee.
  10. #10 Re: Traction control wont turn on. Need help
    Feb 2013
    37.295091, -121.930053
    You must hit the button to disable it. So burning the tires off with the button clicked is suppose to happen. No vehicle made has the traction control disabled when you start the car, they all require you to disable it somehow. It's a safety feature. And just common sense.
    there fixed it
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  11. #11 Re: Traction control wont turn on. Need help
    GT Level Member Jaredthefail's Avatar
    Nov 2015
    Olive branch, MS
    This happened to me to, but it was when I replaced the bulb for Trac off that I found out it was off all the time. And just to make sure, I spun the wheels.
    I also don't have an abs light or any check engine lights.
    I thought it might be the dic itself but I'm not sure
  1. Replies: 2
    Last Post: 05-11-2016, 12:58 PM
  2. Can't Turn Off Traction Control..
    By 01Blackgtp in forum PCM Tuning
    Last Post: 08-07-2014, 05:27 PM
  3. Traction control light only traction control
    By ccoimbre in forum General Grand Prix Discussion
    Last Post: 02-09-2014, 01:02 PM
  4. ABS and Traction Control not working but no ABS or Traction Control lights
    By jruether11 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2013, 04:40 AM
  5. traction control wont work
    By python1986 in forum Introductions/Noob Questions
    Last Post: 02-20-2013, 12:09 AM
