I spent the better part of 3 hours trouble shooting my ac clutch. I finally determined that I am not getting any power to the relay on the lower terminals. My understanding is that if you bridge 30 to 87 it will close the circuit and engage the AC clutch bypassing the high and low pressure checks. When I do this nothing happens. I wound up jumping 12v to the paper clip when I shorted the circuit and the compressor engaged immediately.
I have checked all of my under hood fuses as well as in car fuses. The only other thing I can think of is a fault in the wire somewhere. I pulled the back of the under hood fuses box off and ran my multi meter and still was not getting power at that wire. Any harm in running a 12v directly to the relay position if I can figure it out?
