Thread: tps code popped up after this
Results 1 to 5 of 5
weissmertz tps code popped up after this 05-25-2016, 05:29 PM
FordMan77 Re: tps code popped up after... 05-25-2016, 06:58 PM
weissmertz Re: tps code popped up after... 05-26-2016, 04:19 PM
SgtMarshal Re: tps code popped up after... 05-26-2016, 04:32 PM
weissmertz Re: tps code popped up after... 05-26-2016, 06:09 PM
  1. #1 tps code popped up after this
    Jan 2015
    illinois
    99 gtp wifes car while she was driving to work for about 3 miles first start in morning it just died twice she calls from side of road so i told her to try to start again all good after that. no lights so i took it for a ride the next day did the same to me . to get it going just had to keep foot on gas then it came out of it ran just fine for a couple miles did it again same thing so i went home then the ses light came on 2 codes p0101 p0121 tps and maf so i changed tps cleared codes took it for a ride same thing same codes could my computer be bad or could a bad maf do this also .dont want to just start buying sensors. what would you do next?
  2. #2 Re: tps code popped up after this
    St. Louis
    Check the fuse for the MAF, and also the wiring to it. A lot of times the harness can be bad causing weird issues like this.
  3. #3 Re: tps code popped up after this
    Jan 2015
    illinois
    check this out .drove it last night no issues and the check engine light is off huh
  4. #4 Re: tps code popped up after this
    Kemmerer, Wyoming
    I've had issues with the TPS in the past, and sometimes the fault just goes away. in my case, the problems typically arise after I have changed the throttle body, so a different TPS was installed. There is a TPS relearn procedure that is supposed to fix any TPS problems, but eventually the pcm relearns what it needs.
  5. #5 Re: tps code popped up after this
    Jan 2015
    illinois
    hope that is it had a mazda protege that just kept poppin up codes and it ended up being the computer
  1. 3 Warnings just popped up
    By mcbassin in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2015, 11:16 AM
  2. P0420 just popped
    By Fahrenheit in forum General Grand Prix Discussion
    Last Post: 09-15-2013, 11:46 PM
  3. P0332 popped up on the way home
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2012, 08:34 AM
  4. Ignition issues, maybe popped a piston?
    By Summer Time Anytime in forum General Tech Discussion
    Last Post: 08-31-2011, 11:16 PM
  5. 99 GTP Popped Codes, and questions for a newbie.
    By Fricker in forum General Tech Discussion
    Last Post: 09-23-2010, 05:17 PM
