A few months ago my car would start and run intermittently and eventually it lead to just a short crank but no start situation as if the fuel was being turned off and computer cutting the signal. I checked all connections, fuses, starter, and battery. Battery is new and fully charged. Starter was tested OK. Intermittently a key relearn would work but now no longer does. I bought a new key in hopes that I could relearn with it but symptoms remain the same with either key. Replaced the ECM yesterday with one programmed for my VIN. Still symptoms remain the same. I'll try to attach a video showing and attempt to crank but no start situation. The video was from a few weeks ago. But Now, before and after the ECM swap, I get no attempt to crank or start. Just lights And dings. Throughout the entire ordeal from beginning until now, I've never seen the security light on the dash.
Is it possible that an O2 sensor could cause this?
