Thread: Some more top swap questions! Yay!
Page 69 of 71 FirstFirst ... 19596768697071 LastLast
Results 1,361 to 1,380 of 1411
  1. #1361 Re: Some more top swap questions! Yay!
    you try being in 3 rd before you mash it yet? any better that way? im talking hwy speed.
  2. #1362 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    3rd and mashing it has the same effect if i put it in 2nd though then mash it no kr. Although this isnt hwy speed so far ive only tested this on the 40-50mph range
    Sent from my LG-D851 using Tapatalk
  3. #1363 Re: Some more top swap questions! Yay!
    Oct 2015
    Can you check out the (maf max positive/negative airflow change) tables idk what those are even for but i see a bunch of red cells and i dont like red cells lol
  4. #1364 Re: Some more top swap questions! Yay!
    id get under it and see if you see any marks where the dp might be hitting. when you mash it the engine can rock some times.
  5. #1365 Re: Some more top swap questions! Yay!
    Oct 2015
    Well i got under it and didnt see any marks its about 1 1/4" away from the sway bar the only thing really close to it i believe are power steering lines. There probably only a half inch away there skinny silver lines but didnt notice any visible marks on those either
  6. #1366 Re: Some more top swap questions! Yay!
    dont mash the gas????? i wish i had a answer.
  7. #1367 Re: Some more top swap questions! Yay!
    Oct 2015
    Fair enough ill do some more research on it i saw some people saying that the tcc might be taking to long to unlock or something of that sort thanks scotty everything else looks pretty good. Ill get the fuel trims back to normal
  8. #1368 Re: Some more top swap questions! Yay!
    you can scan for tranny stuff. then maybe tune the tranny to fix it up.
    i just dont fully understand the tranny myself. like what to change and why. ive not even looked for any info on it. i put the billboost tans tune in mine and i like it as is. so i dont play with it. sadly that tune wont work in your n/a tranny as far as i know.
  9. #1369 Re: Some more top swap questions! Yay!
    Oct 2015
    Lol ya i dont kniw anything about tranny stuff or just anythinggl tuning related but ill start going through the files and see what if anything is changed from stock.
  10. #1370 Re: Some more top swap questions! Yay!
    you will need a na bin file for your year car, open both bins up then check the files side by side.
    you have a gtp bin file now, the stock tab is going to show the values for the HD tranny. so they are not going to match.
  11. #1371 Re: Some more top swap questions! Yay!
    Oct 2015
    Okie. I think the drop box has some l36 bins
  12. #1372 Re: Some more top swap questions! Yay!
    oh it does for sure.
  13. #1373 Re: Some more top swap questions! Yay!
    Oct 2015
    So just looking over the files real quick i did notice on my current tune the downshift tables are different from that of a stock l36 or l67
  14. #1374 Re: Some more top swap questions! Yay!
    im sure hes tuned the trans up some, dont bother comparing to the l67 file. its not the same at all.
    you can export the trans file save as a csv file, then drag the stock file from the l36 bin into the gtp bin. see if it changes things.
    both bins open, one click on the l36 trans file will turn it blue, then right click and drag it to the transmission file to your bin. a mass import window will open up and it will all copy over. takes a few minutes to finish. it will say mass import complete when its done.
    make yourself a folder, keep it on your desktop, keep all your bins and files in one place so you dont lose em. make sure you name stuff too so you know what your looking at later on.
  15. #1375 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok! Do you know anything about upping the line pressure at all currently it is unchanged but i heard its a good thing to do but i dont know by what increments to up it.
  16. #1376 Re: Some more top swap questions! Yay!
    im sure other guys know more about tranny settings. im lacking there. maybe start a new thread in the tuning section for trans setting. i know others play with it.
  17. #1377 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks scotty!
  18. #1378 Re: Some more top swap questions! Yay!
    take and post a screen shot of that kr spike at the shift too. helps when you can see a scan.
  19. #1379 Re: Some more top swap questions! Yay!
    Oct 2015
    I flashed the stock torque management and shift time tables and if anything it made ut slightly worse so im back to where i was. No mashing on it for now!
  20. #1380 Re: Some more top swap questions! Yay!
    Oct 2015
    Hey scotty what did you do witg your tune when you got your 1.9s?
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
