you try being in 3 rd before you mash it yet? any better that way? im talking hwy speed.
3rd and mashing it has the same effect if i put it in 2nd though then mash it no kr. Although this isnt hwy speed so far ive only tested this on the 40-50mph range
Sent from my LG-D851 using Tapatalk
Can you check out the (maf max positive/negative airflow change) tables idk what those are even for but i see a bunch of red cells and i dont like red cells lol
id get under it and see if you see any marks where the dp might be hitting. when you mash it the engine can rock some times.
Well i got under it and didnt see any marks its about 1 1/4" away from the sway bar the only thing really close to it i believe are power steering lines. There probably only a half inch away there skinny silver lines but didnt notice any visible marks on those either
dont mash the gas????? i wish i had a answer. :th_thumb-down:
Fair enough ill do some more research on it i saw some people saying that the tcc might be taking to long to unlock or something of that sort thanks scotty everything else looks pretty good. Ill get the fuel trims back to normal
you can scan for tranny stuff. then maybe tune the tranny to fix it up.
i just dont fully understand the tranny myself. like what to change and why. ive not even looked for any info on it. i put the billboost tans tune in mine and i like it as is. so i dont play with it. sadly that tune wont work in your n/a tranny as far as i know.
Lol ya i dont kniw anything about tranny stuff or just anythinggl tuning related but ill start going through the files and see what if anything is changed from stock.
you will need a na bin file for your year car, open both bins up then check the files side by side.
you have a gtp bin file now, the stock tab is going to show the values for the HD tranny. so they are not going to match.
Okie. I think the drop box has some l36 bins
oh it does for sure.
So just looking over the files real quick i did notice on my current tune the downshift tables are different from that of a stock l36 or l67
im sure hes tuned the trans up some, dont bother comparing to the l67 file. its not the same at all.
you can export the trans file save as a csv file, then drag the stock file from the l36 bin into the gtp bin. see if it changes things.
both bins open, one click on the l36 trans file will turn it blue, then right click and drag it to the transmission file to your bin. a mass import window will open up and it will all copy over. takes a few minutes to finish. it will say mass import complete when its done.
make yourself a folder, keep it on your desktop, keep all your bins and files in one place so you dont lose em. make sure you name stuff too so you know what your looking at later on.
Ok! Do you know anything about upping the line pressure at all currently it is unchanged but i heard its a good thing to do but i dont know by what increments to up it.
im sure other guys know more about tranny settings. im lacking there. maybe start a new thread in the tuning section for trans setting. i know others play with it.
Ok thanks scotty!
take and post a screen shot of that kr spike at the shift too. helps when you can see a scan.
I flashed the stock torque management and shift time tables and if anything it made ut slightly worse so im back to where i was. No mashing on it for now!
Hey scotty what did you do witg your tune when you got your 1.9s?
