Thread: Some more top swap questions! Yay!
Page 1 of 71 1231151 ... LastLast
Results 1 to 20 of 1411
  1. #1 Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys so im putting together all the parts for my top swap and have read through all the threads on here, i just have two questions. The first is i have a 99 gt so my fuel injector clips will work with the supercharged correct? Finally im trying to find some heads right now but have had no luck except for ones with over 175xxx miles. Are miles on heads that big of a deal as long as you have them resurfaced maybe a valve job anything else? Thanks guys
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Some more top swap questions! Yay!
    Miles don't matter a whole lot. Getting them cleaned up never hurts.
    And 9/10 used heads will already have a crack between at least one of the valves, not something to worry about as they affect nothing.
  3. #3 Re: Some more top swap questions! Yay!
    Oct 2015
    So would i need a valve job? And is there anything i should replace? Like spring etc.
  4. #4 Re: Some more top swap questions! Yay!
    the injector clips should be the same, but you also need the l67 rail and injectors, if your junk yard hunting just take it all.
    if your looking for jy heads, id at least lap the valves, and change the springs and valve seals. if your planning on rockers or a cam with it, springs need to happen anyways.
    then as long as you got em in hand, you can always port them or at least clean them up. inside the ports is so rough. any smooting will help it flow better.
    stock casting in the exhaust port they all look like this.
    with some time invested you can make em pretty.
  5. #5 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks scotty ill decfinately be doing that
  6. #6 Re: Some more top swap questions! Yay!
    diy porting will run you about a $100 in tools. but well worth it. i spent a easy 8 hrs per head. maybe a bit more with the valve lapping.
    load of pics from my top swap. http://s1097.photobucket.com/user/sc...?sort=3&page=1
    another folder of pics. http://s1097.photobucket.com/user/sc...?sort=3&page=1
  7. #7 Re: Some more top swap questions! Yay!
    Oct 2015
    Can i use these same tools to port my soon to be new lim, supercharger, and possibly rear exaust manifold
  8. #8 Re: Some more top swap questions! Yay!
    you "NEED" headers for a top swap. so add them to the list.
  9. #9 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok so with the SD headers i would also need an o2 extension correct? Anything else?
  10. #10 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by suitercrew View Post
    Get band clamps, o2 extension, copper rtv...you'll be good.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  11. #11 Re: Some more top swap questions! Yay!
    Quote Originally Posted by ScottyDoggs View Post
    Quote Originally Posted by timboku View Post
    This this this
    04 Comp G.
  12. #12 Re: Some more top swap questions! Yay!
    two 2.25 band clamps, two, 3 inch band clamps, unless you need a cat, then you can weld the cat in and not need the two 3 inch clamps.
    reuse the stock head to manifold gaskets. toss all the gaskets and clamps they give you in the trash, all but the cat back gasket, use that one.
    yes you need a o2 extension. and maybe a new rear o2 if yours dont come out the dp. or a tune with the rear o2 deleted. you will need a tune for this.
  13. #13 Re: Some more top swap questions! Yay!
    Oct 2015
    Well ill need a new tune anyway for the top swap now i know having a tune would be best from a shop with a dyno and stuff but how would an intense or reptile tune work out?
  14. #14 Re: Some more top swap questions! Yay!
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    In-car tunes are the best, then you can tweak it so its just right. Reptile is good though, tell him your mods.
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  15. #15 Re: Some more top swap questions! Yay!
    id get a reptile tune cause hes about as cheap as your gonna find, and his tunes are pretty good too.
    or buy a tuner and tune it yourself. dhp box runs like 250 ish brand new.
  16. #16 Re: Some more top swap questions! Yay!
    Oct 2015
    Thanks kaiser now i just need you to work me a deal on those heads and maybe some other stuff if their in good shape!
  17. #17 Re: Some more top swap questions! Yay!
    Jun 2015
    I can take as many detailed pictures of the two sets of heads as you'd like! I'll look them over best I can as well. Just PM me with whatever you need, any questions, wanted pictures, ect. just let me know.
  18. #18 Re: Some more top swap questions! Yay!
    are you two local? cause shipping just heads costs about a 100 bucks.
  19. #19 Re: Some more top swap questions! Yay!
    Oct 2015
    Noo
  20. #20 Re: Some more top swap questions! Yay!
    that whole package shipped could hit $150 easy and fast.
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
