Scotty do you think i could be having problems from running too cold of plugs
Sent from my LG-D851 using Tapatalk
Ya know that's a thought you don't really have to many mods or are running that much boost
Sent from my SM-G920V using Tapatalk
Ya i know they say 104s are for more modded i just thought that with the higher compression i needed them. Then also that (pending) cel for cylinder 3 missfire had me wondering
Well you originally planned to do rockers 104's make sense with rockers
So you still have a misfire?
True. And no i dont have a missfire i was just scanning the car and i got a pending code for a missfire. Changed that plug wire out and so far it hasnt come back around
Oh that's good
Yea a N/A and a sc 3800 stock both run the same plugs
So heres the question of the day. Can running to cold of plugs cause kr?
Yupp
So i should just go up one heat range right? Which would be what lol?
A colder plug won't cause kr, you aren't running iridium plugs are you?
No copper 104s
Perfect
I don't feel like you have supporting mods I'd run stock it pretty much is a stock gtp
Ok can anyone give some knowledge on why my car feels like it shakes more after the swap. I have brand new trans and motor mounts a couple thousand miles ago
Shakes while it's idling?
Yes. Not dramatically or anything but its deffinately there.
Rough idle can cause it
I thought maybe the shaking could be from the plugs not igniting the fuel properly
I dont really have a rough idle. It surges a little on cold start up and if i just barely tap the gas when in park itll rev up and then drop down pretty low, kinda the same thing when my powersteering kicks in
The same thing when your powersteering kicks in? You mean when you turn the wheels in park? Yea that's normal
