I drove the car to my exaust shop they only charged 20$ to put in a new o2 bun in a much better spot and i went ahead and had them install a magnaflow cat while they were in there 150$ out the door
Sent from my LG-D851 using Tapatalk
sweet. now to get the blower turning lol
Not bad
Ya i called a bunch of places for the hb no one would just take the bolt off for me so while i was at the muffler shop there is an autorepair shop right next door and there going to just swap the hb and put the new belt on for 160$ which kinda sucks but i need my car today and the other impact i was gonna buy which is 2500ft lbs is 250 so i figured whatever just let the shop do it.
A couple other places quotes me 400+ dollars to swap the hb and a few other shops said they didnt even want to touch the modded car lol
Is it done then?
f ing criminals. 400 to swap a balancer, that robbery.
id keep looking, hell maybe bring your air gun, and ask to use their air line. pretty sure wheel turned you can get a gun on the bolt and break it free. just leave the splash shield off.
you had not said how large your air tank is, i got a feeling its to small for the gun to work at its max power. a real compressor should get the job done.
So im at the repair shop that quoted 160 to swap the hb and do the case learn. They had a 1200ft lb impact that didnt take it off finally they were able to heat the crap out of the bolt and use the impact and finally got it off woool!!
thats a hot one lol
persistence pays off for sure. always keep shopping a round.
you got the belt on now?
That's how I got mine off the first time, lots of heat and a good impact... even though I managed to warp the HB in the process. Then you'll wonder why in the hell the factory decides to cover the whole bolt in red locktite.
So i got it all done and im officially topswapped!! I took it for a test run and was at 4 degreees of kr at wot how bad is that?
4* of kr left unchecked will lead to problems. how much timing advance was it showing? do you have a tuner yet?
Idk i just got a reptile tune i will probably get an in car tune next week
once the fuel trims learn the kr may go away some. what plugs you running? im running 104 in mine. gaped to 0.50.
Im running 104s i believe happed to .50 also either .50 or .55 cant remember
What pulley do you have?
Sent from my SM-G920V using Tapatalk
Stock
Oh wow that's ridiculous
Ya?
