Most auto parts stores don't even have impacts let alone rent them
Sent from my SM-G920V using Tapatalk
If you know anyone with a shop or something I used a cordless snap on impact
Ok ill check the rental in the morning or just see if my dad can bring his over tomorow. Now the map sensor wires are they excactly the same for the l67 map sensor
Sent from my LG-D851 using Tapatalk
I'm not sure on that I'm using my L36 map sensor
if they are the same colors match em up. if not the same colors one wire might have a line on it, match the two with lines together.
just twist and tape the wires till you know its working right, aka not setting a code. if all goes well solder them in.
Lol yea and a couple map sensors later.....
Doesnt a black line usually mean its a ground?
It all depends how about some pictures of both sets of wires?
Old plug http://i1030.photobucket.com/albums/...psn2rr3jra.jpg
New plug http://i1030.photobucket.com/albums/...psr1irgiu2.jpg
see the a b c on the plugs, id try to match that up.
Ok well see haha
What goes in between the coil pack bracket and the tensioner is there a bolt or what. I cant get the tensioner to sit right
the long stud goes through the large hole on the coil bracket, then line up the bolt holes.
zoom in on this pic,
http://i1097.photobucket.com/albums/...ps7izvpwp6.jpg
on the inside of the bracket is a 1/2 circle, the icm harness goes in there, watch you dont pinch the harness when bolting it down.
Ya but does anything go on the stud right after the coil bracket and before the tensioner. I put bracket on then very next thing was the tensioner and it just kind of sits funny
Nothing goes on in between the braket and tensioner there's a little nipple on the back side of the tension that sides face you on top of the braket so it doesn't spin you probably just have to rotate it a litlle
http://uploads.tapatalk-cdn.com/2016...ebb5be962c.jpg
So this is good? http://i1030.photobucket.com/albums/...psqt3kxzvv.jpg
http://i1030.photobucket.com/albums/...ps5fbkxgv5.jpg
Looks good!
