Thread: Some more top swap questions! Yay!
Page 31 of 71 FirstFirst ... 21293031323341 ... LastLast
Results 601 to 620 of 1411
  1. #601 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Not tuning for methanol is one strategy some people follow because in the event of a methanol pump failure your afr is still the same
  2. #602 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    It will still run fine without a tune?
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  3. #603 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    it should, don't see why it wouldn't. its just like adding race gas to your gas tank
  4. #604 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    You would think it'd be to rich
  5. #605 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    it will be rich, not sure how much.
  6. #606 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Do we put copper spray on a felpro head gasket? What thread locker should i use on the head bolts?
    Sent from my LG-D851 using Tapatalk
  7. #607 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    No and the head bolts come with locktite on the threads
  8. #608 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok i just didnt know if the stuff on the bolts was good enough. There isnt anything else i need to know about the head gasket is there? Rtv in the corners or anything?
  9. #609 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    No
  10. #610 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok cool
  11. #611 Re: Some more top swap questions! Yay!
    i did the copper spray on both sides of the felpro head gaskets.
    make sure you clean the head bolt threads with a thread chaser.
  12. #612 Re: Some more top swap questions! Yay!
    Oct 2015
    The actual bolts or the volt holes?
  13. #613 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Holes lmao
  14. #614 Re: Some more top swap questions! Yay!
    Oct 2015
    Lol thats what i thought
  15. #615 Re: Some more top swap questions! Yay!
    Oct 2015
    Did i get the right ones scotty?
  16. #616 Re: Some more top swap questions! Yay!
    wheres the 3 rd one?
  17. #617 Re: Some more top swap questions! Yay!
    Oct 2015
    Theres supposed to be 3???!!... Haha i got it but these are the right ones? I still need to get washers they only had little baby ones at the store. Also i got my dads puller but he has the recessed fitting on it instead of the cone shaped one is that a problem?
  18. #618 Re: Some more top swap questions! Yay!
    pics of puller? should be ok.
    you can test fit the bolts in the balancer you have in hand.
  19. #619 Re: Some more top swap questions! Yay!
    Oct 2015
    I shall do that once i get home ill take a pic of my puller in a little but i already fit it and the bolts slip through i did get the baby washers and they kinda fit but only if you angle perfect cause if the washer goes in even slightly off center then itll slip through too
  20. #620 Re: Some more top swap questions! Yay!
    you may have to double up on the washers.
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
