Thread: Some more top swap questions! Yay!
Page 30 of 71 FirstFirst ... 20282930313240 ... LastLast
Results 581 to 600 of 1411
  1. #1 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ya when my dad stops ignoring me ill see if he still has the reciept and can get the item number. We just figured they went with a different design
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Some more top swap questions! Yay!
    when you change the whole canister they add a new pig tail for one of the plugs. you cut off the stock one, install the new pig tail provided.
  3. #3 Re: Some more top swap questions! Yay!
    Oct 2015
    Yes thats what i did! But why do they make the plugs different?
  4. #4 Re: Some more top swap questions! Yay!
    Quote Originally Posted by suitercrew View Post
    up graded designee i guess. no one can leave well enough alone. had to do the same for my 03 gmc too.
  5. #5 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Where do I get methonal?
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  6. #6 Re: Some more top swap questions! Yay!
    Quote Originally Posted by Tonkin2000GT View Post
    believe it or not, you can use -20 washer fluid. yup you read that right, washer fluid.
  7. #7 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    For real? -20 so any washer fluid that goes down to -20? How much of it do you actually use?
  8. #8 Re: Some more top swap questions! Yay!
    you fill the res tank, the spray nozzles dictate how much is sprayed. some how its only sprayed when your wot or starting to hit boost, theres a controller for it.
    ive not looked into much (like how the set up works) cheaper then a IC thats for damn sure. way less work to install too.
  9. #9 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Okay I was just curious about how much meth you use for a gallon of gas ya know?
  10. #10 Re: Some more top swap questions! Yay!
    its not a full time deal, only when in boost, then it sprays.
  11. #11 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    How do you tune for that?
  12. #12 Re: Some more top swap questions! Yay!
    Oct 2015
    But what happens for when the pump for the meth goes out and then you explode your motor lol?
  13. #13 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
  14. #14 Re: Some more top swap questions! Yay!
    Oct 2015
    I mean i guess if maybe you had an aeroforce and kr was constantly in your face youd probably have warning to stop driving
  15. #15 Re: Some more top swap questions! Yay!
    why you scan for kr full time.
  16. #16 Re: Some more top swap questions! Yay!
    Oct 2015
    Scotty would you recommend a meth set up for my setup ?
  17. #17 Re: Some more top swap questions! Yay!
    im not sure if having a tuner helps with meth or not, or if it needs to be tuned for it. with a tuner you can play with your timing at least. no tuner and your stuck with what you got.
  18. #18 Re: Some more top swap questions! Yay!
    Oct 2015
    Should i replace the hb seal?
  19. #19 Re: Some more top swap questions! Yay!
    as per billboost, dont change it unless you see its damaged. install the l67 balancer, if it leaks you need to change it. bill said hes only had a few that leaked. the times the owner wanted a new seal, it leaked on him lol
    i changed my seal and nothing good came of it. 4 days of trial and error i guess lol
  20. #20 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
