Thread: Studder Issue
Results 1 to 11 of 11
  1. #1 Studder Issue
    Nov 2014
    Grand Rapids, MI
    I bought my 2000 grand prix gt about a year ago.
    A few months after purhasing it, it started to have a slight studder while accelerating when it got hot.
    Over time it has gotten progressively worse and now studders when accelerating all the time.
    Lookin for ideas on what it could be. Its also very intermitent. Sometimes its worse than others. Its just in all much worse than it used to be.
  2. #2 Re: Studder Issue
    Feb 2013
    37.295091, -121.930053
    i would try and clean the maf. then spray it down with carb cleaner for any vacuum leaks. other than that is it throwing any codes?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Studder Issue
    Nov 2014
    Grand Rapids, MI
    Its throwing a couple emission codes. Ive cleaned the maf already.
    How would i use carb cleaner to find vacuum leaks?
  4. #4 Re: Studder Issue
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    You spray the vac fittings and lines. if it starts to idle better, the last thing you sprayed is the leak.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  5. #5 Re: Studder Issue
    Apr 2014
    South Haven, MI
    The carb cleaner basically plugs the leak for a second
  6. #6 Re: Studder Issue
    Feb 2013
    post up your codes and we can help even more
  7. #7 Re: Studder Issue
    Nov 2014
    Grand Rapids, MI
    It idles fine. Only studders during acceleration.
    Ill get those codes asap. I know i wrote them ob my phone somewhere.
    Also there was one point where i could punch it to make the studder quit. So it would only do it mid throttle.
  8. #8 Re: Studder Issue
    SE Level Member keatonregal's Avatar
    Mar 2015
    Port Huron, MI
    supercharged? Could be a spark plug boot going bad, happened to mine, everytime I would roll into the slightest bit of boost, it would start to bog and hesitate, just my $.02, a tune up is never a bad thing
    1999 Buick Regal "Betty White"
    NIC Cam FSIC E85 Built Trans Flaky Paint
    Ported Aluminum Coolant Elbows
  9. #9 Re: Studder Issue
    Mar 2015
    Port Huron, MI
    Just re-read and saw its a GPGT, still might be an issue, I would do a maf clean and a tune up if it hasn't been done in a while
  10. #10 Re: Studder Issue
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    Funny, I just started to have the same issue with my NA 40th Anniversary. It first happened about 2 weeks ago, very slight. Now every time I drive it, I feel a slight miss when accelerating. At first, it seemed to only happen when I first started out from a dead stop. Now, it is happening at speeds up to 40mph, mostly when going up hills. I plan to check all that was mentioned above. The MAF has never been cleaned. Also, all the vacuum lines are original. So, I may find the problem there.
  11. #11 Re: Studder Issue
    Aug 2013
    Pittsburgh, PA
    Here is an update to the issue I was experiencing with the L36:
    the problem was with the MAF sensor, as in it was bad. When I first started having the engine miss, it was very intermittent. Then, the miss started to occur more often. At first, I had no SES light which usually comes on when there is an miss. But when the light came on, the code was a "P0102 MAF circuit low input". I sprayed out the sensor with MAF sensor cleaning spray and it did not help. I installed another known good MAF sensor and the car ran fine.
    I was about to install new plugs and wires believing that was the problem. With over 124K miles on the plugs and wires, I plan to install new ones anyways.
    It is always good to know that I can rely on the advice on here about what to check and fix when I have a problem with the old GP.
  1. Wheel Bearing Issue or Tire Issue
    By ibra0078 in forum Tires & Wheels
    Last Post: 06-07-2013, 05:12 AM
  2. slite studder when cold start and rev
    By beattie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2013, 06:52 PM
  3. 2004 GTP Studder/Bogging/RPM cut issues.
    By 04ncgtpguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2012, 08:57 PM
  4. weird studder and lag
    By 99gtp3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2012, 01:14 PM
  5. FIXED!! Engine studder, tach drop, P1361 (video added)
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 04:14 PM
