Thread: 04+ double din install
Results 1 to 9 of 9
  1. #1 04+ double din install
    GTX Level Member xxpappas13xx's Avatar
    Aug 2011
    Michigan
    For my 2005 grand prix gtp (non monsoon) and my brothers 2006 gxp (monsoon) we got power acoustik pd-651b radios. They gave us this dash kit (gmk422) and harness for our cars, but upon further reading there is a grand prix specific dash kit (Metra 95-3527) which I will hopefully get changed out. I was then was wondering if I can get the plain harness to work on my car(gwh416) and if the other will work on the gxp (soo-gm15). I saw the suggested is gmos-01 for non-monsoon and gmos-04 for monsoon to keep the chimes but any help is appreciated. Thank you -Zach
  2. #2 Re: 04+ double din install
    Mar 2013
    Canada
    When I did my install with a double din android screen I went with the gmos-01. Made the install a lot easier and I was able to keep my chimes
    Sent from my SGH-I337M using Tapatalk
  3. #3 Re: 04+ double din install
    Aug 2011
    Michigan
    Quote Originally Posted by ibra0078 View Post
    These people really fvcked me over. At first they tried to say 04+ stock is not a double din, then all this too! Time to go back and get it, just wasn't sure if the other harness for the gxp will work the same. I appreciate it though
    Sent from my SM-N910V using Tapatalk
  4. #4 Re: 04+ double din install
    Mar 2013
    Canada
    Not sure if the other harness will work but I know to retain the chimes you need the gmos-01. I got everything from Amazon, does your HU have steering wheel control built in to it?
  5. #5 Re: 04+ double din install
    Smh
    But yea gmos-01 non monsoon
    Gmos-04 monsoon
    Not sure if they're a cheaper harness available but it worry just spending the coin and getting it right the first time
    04 Comp G.
  6. #6 Re: 04+ double din install
    Aug 2011
    Michigan
    I don't think so since it's lower quality, but that other harness is supposed to retain the steering wheel controls only for "name brand" stereos like kenwood, pioneer, etc.
  7. #7 Re: 04+ double din install
    Oct 2011
    Toledo, OH
    It says it is steering wheel compatible. Does it have what looks like a headphone jack in the back?
    7"
  8. #8 Re: 04+ double din install
    Mar 2013
    Canada
    no my after market China brand just had a wire that says key 1 and key 2. Cut the steering wheel wire on the harness on the vehicle and tap it into the key 1. Make sure you ground the other wire from the car harness as the steering wheel wire on the car is two wires that you use
  9. #9 Re: 04+ double din install
    Aug 2013
    McDonald PA
    Subbing
  1. Double Roller install help.
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2015, 03:53 PM
  2. 06 gxp double din install but no sound
    By Derickgxp in forum Audio, Security & Visual Electronics
    Last Post: 05-26-2014, 10:50 AM
  3. Double Din DVD Player Install
    By WolfLord in forum Audio, Security & Visual Electronics
    Last Post: 08-29-2013, 01:26 PM
  4. Double Din Install
    By windowrattler in forum Audio, Security & Visual Electronics
    Last Post: 02-22-2012, 09:42 AM
  5. Double din dvd nav digital dic and hud install
    By thunder71173 in forum Audio, Security & Visual Electronics
    Last Post: 11-14-2010, 03:39 AM
