Thread: Car won't start need help
Results 1 to 16 of 16
  1. #1 Car won't start need help
    SE Level Member 97GPJJ's Avatar
    Dec 2012
    grand rapids
    On my 00 gp gt the car will just turn over it will fire for like 2 seconds . Also all the dash lights flash when key is in ignition the fuel pump relay just sits there clicks any ideas?
    97 grand prix - sold
    2000 grand prix gtp xp cam,3.2 pulley ,tog headers
  2. #2 Re: Car won't start need help
    I'm a bit confused.. your sig says GTP, your description says GT. If you have a GTP, try the picture below
    If not.. unplug the maf and see if it stays running. Another thought is that security is pissed off and you should relearn the key.
  3. #3 Re: Car won't start need help
    sig says 00 gtp. replay trick should get it going
  4. #4 Re: Car won't start need help
    Quote Originally Posted by ScottyDoggs View Post
    I covered both scenarios.. go "replay" your relay Bumble Bee guy
  5. #5 Re: Car won't start need help
    Dec 2012
    grand rapids
    I haven't been on here in a while and yes it is a gt that I have
  6. #6 Re: Car won't start need help
    Dec 2012
    grand rapids
    I'll give it a shot and let you know thanks a lot
  7. #7 Re: Car won't start need help
    that only works with a gtp. try the maf unplugging like bill suggested.
  8. #8 Re: Car won't start need help
    Dec 2012
    grand rapids
    I unplugged the maf still wouldn't start then the iac was clicking also the fuel pump won't turn on
  9. #9 Re: Car won't start need help
    theres a cap on the fuel rail, front of the engine, take it off, and push the pin inside with the key to run, gas should spray out with good pressure.
    if nothing comes out or very little, your fuel pump took a dump.
  10. #10 Re: Car won't start need help
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    fuel pump relay itself ?
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  11. #11 Re: Car won't start need help
    Dec 2012
    grand rapids
    I'm thinking a security issue relay is new pump is new
  12. #12 Re: Car won't start need help
    you hear it priming? the pump that is?
    you check for fuel pressure? just cause its new dont mean its good still. if you touched it, test it. aka it was the last thing you touched right?
  13. #13 Re: Car won't start need help
    Dec 2014
    Maryland
    yep..i've had plenty of "new" parts go bad shortly after install ... last one was an ac delco upstream O2 sensor. lasted 2 weeks and threw a code.
  14. #14 Re: Car won't start need help
    Dec 2012
    grand rapids
    Doesn't prime
  15. #15 Re: Car won't start need help
    check the relay cause they can fail. swap it with the one next to it. its the same.
    if that dont fix it open up the trap door and double check the wires if you had to cut the old plug and put a new one on the new pump like i just had to do.
  16. #16 Re: Car won't start need help
    Dec 2014
    Maryland
    i said that an hour ago ...lol
  1. 06 Base Rough Start with Auto Start
    By jenebo in forum 04+ Specifics
    Last Post: 08-30-2016, 11:24 AM
  2. Installing remote start on non-remote start car
    By GPmanter in forum General Grand Prix Discussion
    Last Post: 01-29-2016, 11:39 AM
  3. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  4. 1990 3.1 lit hard start/ no start. fuel pressure prob
    By wadd in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2015, 07:22 AM
  5. how to>new fob for auto start, already have auto-start installed
    By Timmaayy2121 in forum Introductions/Noob Questions
    Last Post: 12-20-2014, 06:53 AM
