Thread: Double Din Install
Results 1 to 16 of 16
  1. #1 Double Din Install
    Here is a quick pic of how my double din install turned out. I wanted to get it as close to a "factory" look as I could and I think it turned out pretty good. Any questions or comments feel free to ask.
    http://s192.photobucket.com/albums/z12/windowrattler/Grand%20Prix/?action=view&current=Photo0015.jpg
  2. #2 Re: Double Din Install
    looks good.
    do you do audio for a living?
    just asking because of your other PB pics.
  3. #3 Re: Double Din Install
    Nope. It's just what happens when you are too poor to pay someone else to do it. I've been doing car stuff for a good 14 years now and if you don't try something then you'll never learn how to do it. This was my first time modding a dash to this extent and patience is the key. Plus if you want it done right you're better off doing it yourself.
  4. #4 Re: Double Din Install
    SE Level Member ham4864's Avatar
    Nov 2010
    usa
    +1 on the install that stuff is simple(but it can be a pain in the ars some times)
    WhatAPrix
  5. #5 Re: Double Din Install
    Hmm..i don't consider a custom dash bezel the simplest install but it's not the hardest thing in the world to do.
  6. #6 Re: Double Din Install
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    Thats nice bro great job. I to have been doin system stuff for years and have been thinkin of a way to do that. Time to start savin for an indash.
  7. #7 Re: Double Din Install
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    heres a pic of mine I believe we have the same deck mines a dnx 5140. Not the toughest thing but def not for an newb either
  8. #8 Re: Double Din Install
    Well what I did was mount the screen first. I used four banding straps to secure it into the dash. Then I cut out the middle divider and chopped up towards the vents. I then used 1/4 wood to remake the sides to come out to the screen. Then bondo and a lot of sanding. Originally I was going to have the sides come out flat but decided to put some curve into it. SEM makes a texture spray that I used. It really isn't the same texture but you can't tell unless you are up close and trying to pick it apart. The main idea with the texture is that it can't be smooth or you will notice where I did the work. I then just matched the paint up to the closest SEM product and repainted the whole bezel. Here are a few more pics that I have.
    Photo0010.jpg picture by windowrattler - Photobucket
    Photo0011.jpg picture by windowrattler - Photobucket
    Photo0012.jpg picture by windowrattler - Photobucket
  9. #9 Re: Double Din Install
    Dec 2010
    jacksonville,FL
    went to a shop round my city and shop said it wouldnt look good,so i got a flip out. should waited. looks damn good
  10. #10 Re: Double Din Install
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    yeah nice install on what looks like a kenwood , thinking of doing a pioneer avic d3 in mine , have one from the old days and i know them up one side and down the other . havent done a custom dash in about ooooh 10 years , but now inspired after seeing yours , think its time to break out the dremel , fiberglass and a few other tricks i have
  11. #11 Re: Double Din Install
    Yeah if I had fiberglass skills I could have brought the bezel closer to the sides of the deck. It is necessary to find a dash bezel out of a donor car so your covered. I used a dremel to widen the opening at the top and bottom of the opening a little at a time until it fit snug. Had to trim it all the way up to the bottom of the vents on the top but i would put the deck in the dash hole mount a coupleof the screws and put the dash bezel over it til i got it to fit nice. The foam i was talking about using is to fill the gap on the sides where there is a gap that you can see all the way back to the mounting brackets and thats what I would have filled in with fiberglass ifI could do it.
  12. #12 Re: Double Din Install
    Thanks again for the comments everyone. The shop might have been trying to shy you away from it because of the amount of time it takes to do. They'd have to charge quite a bit to make it worthwhile for them.
    Really the biggest thing when doing stuff like this is patience and imagination. For the radio the start was staring at it and figuring out how to attach it into the dash. I used banding straps. Then dremel time removing the material that was in the way. After that a couple pieces of wood and bondo and ALOT of elbow grease sanding and shaping.
    I was going to get a 2nd bezel to do but then I thought...what if it turns out the first time? Why have a 2nd bezel hanging around? I ended up driving around with no dash for about 4 days while I worked on this. Take your time and you can get good results.
  13. #13 Re: Double Din Install
    Jun 2010
    MN
    can you send me a how too?
    That if you confess with your mouth, "Jesus is Lord," and believe in your heart that God raised him from the dead, you will be saved. - Romans 10:9
  14. #14 Re: Double Din Install
    Quote Originally Posted by alwtkns View Post
    I have a bunch of pics. I'll see if they are on my Photobucket and send post a link. Won't be until sometime after work tonight.
  1. Double din dvd nav digital dic and hud install
    By thunder71173 in forum Audio, Security & Visual Electronics
    Last Post: 11-14-2010, 03:39 AM
  2. Double din in gp
    By Stratguymike in forum Audio, Security & Visual Electronics
    Last Post: 07-07-2010, 04:07 PM
  3. 04-08 Double Din Kit
    By FockerNJ in forum Audio, Security & Visual Electronics
    Last Post: 07-09-2009, 08:54 AM
  4. Double Din
    By kingbrentdwyer in forum Audio, Security & Visual Electronics
    Last Post: 06-17-2009, 04:25 PM
  5. Double
    Last Post: 08-09-2008, 08:06 AM
