Thread: Engine Swap
Results 1 to 5 of 5
  1. #1 Engine Swap
    SE Level Member chrisgotcrisco's Avatar
    May 2015
    How much would it cost to do a engine swap ?
  2. #2 Re: Engine Swap
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Depends on what they run in your area, and how good of a job you want to do. On average, $600 for the engine, $200 for gaskets, maybe ~$100 for various fluids (oil, coolant, maybe some fresh PS fluid, etc). If you don't have a picker and engine stand, those will run about $300 new, you could rent or buy used off CL to save money, though. I'd also set about $200 aside for random stuff that pops up unexpectedly (like new hardware to swap your flexplate over). Or, you could just toss the engine in without replacing any gaskets, use the old oil and coolant that's in your current engine, and save that money. PCM will need to be done if you're (I'm assuming) swapping from an L36 to an L67, factor in that cost if you don't have a tuner or someone with one that can do it locally.
    EDIT: I actually assumed a lot with my post, I have no idea what engine you want to install, or what you want to install it into. Or even if you were talking about the cost of the engine and/or other hard parts at all. If you meant cost of the labor, depends on what your local shops charge, gotta call and ask them.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  3. #3 Re: Engine Swap
    1800-2500 from a shop easy.
    Anywhere from 6-9 hours labor, plus fluids, shop supplies and fee's and tax, then the motor depending on mileage will vary but just assume that any shop will try to make 300-500 off the motor just to cover their ass in case they break something. This is just for a grand prix.
    Some cars call for nearly 20 hours for a R&R, diesel trucks are even more.
  4. #4 Re: Engine Swap
    May 2015
    I gotta 04 Grand Prix GT and I wanted to maybe swap a gtp supercharged engine
  5. #5 Re: Engine Swap
    If your current engine is still good, you would be better off doing a top swap. http://www.grandprixforums.net/threa...s-of-3800-Info
  1. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
